Davidthomas
| posted on 19/1/14 at 04:58 PM |
Car feels nervous!
Recently finished my panther, and as the weather wasn't too bad today I thought I'd take it out to get some miles under my belt. Car feels
good all the way to around 50/60mph but after that the car feels nervous and the steering isn't as sharp.
Any ideas?
Tracking?
jossey
| posted on 19/1/14 at 05:13 PM |
welcome.
can you explain a little better than nervous.
Does the car feel lighter like the air is lifting the front or something like that.
David Johnson
Davidthomas
| posted on 19/1/14 at 05:21 PM |
It feel a little lighter, but most of all the car seem to wonder side to side ever so often.
perksy
| posted on 19/1/14 at 05:23 PM |
What tyre pressures are you running ?
Also what suspension settings does the car have ? Camber, Ride height etc etc
Davidthomas
| posted on 19/1/14 at 05:27 PM |
I'm running about 20psi up front and 30psi on the rear.
Suspension I can't tell you off the top of my head. It was done professionally before the iva.
steve m
| posted on 19/1/14 at 06:19 PM |
I would say the pressures are to high, I run 16psi on all four wheels
Also the roads are very greasy , so would not want to take my car out on them
mookaloid
| posted on 19/1/14 at 07:00 PM |
/\ /\ This
bi22le
| posted on 19/1/14 at 07:03 PM |
If you let go off the steering wheel do you think it will steer straight?
Does it track tram lines in the road?
Have you driven these kind of cars before?
Please read my ring story:
MikeCapon
| posted on 19/1/14 at 07:13 PM |
Front to rear ride heights? You want the rear around 25mm higher than the front or at speed the lift will make the car wander or worse..
www.shock-factory.co.uk
StevieB
A big thing I noticed when I got my first Elise, after all the tin tops up until that point, was that it felt nervous on the road. What it turned out
to be was that the steering was much more direct than a normal car, with loads of feedback. This meant I could feel the car following the road
cambers and imperfection in the surface.
My Indy and Westfield do the same, but I've grown used to it.
Steering feeling light is a bit different though - would be handy to know a few things like what toe in/out you're running, steering rack ratio
and maybe steering wheel size. A small steering wheel on a quick ratio rack with a bit of toe in would make it feel maybe a little twitchy for very
small steering inputs.
As said, maybe try dropping the tyre pressures and see how it feels on the same roads - I run about 18psi all round on my Westfield.
| posted on 19/1/14 at 07:18 PM |
tyre pressures, toe-in front and rear , corner weights.
Davidthomas
| posted on 19/1/14 at 07:34 PM |
Thanks for all the replies guys. Il try and find the print out the garage gave me after they set the car up. As a few have mentioned tyres pressures,
il have a little play with that.
unijacko67
| posted on 19/1/14 at 07:58 PM |
I had trouble keeping my car in a straight line on the motorway and that was the tracking as I'd altered camber and forgot to re-track it up.
I've set it parallel now and completely different car.
http://www.kittenkitcar.co.uk
StevieB
Well, it is the easiest and free-est way of making changes to see how it feels
steve m
| posted on 19/1/14 at 08:42 PM |
I will add, that when I got my car on the road, years ago, the first drive, was ORRIBLE !!
It felt as though I was driving on ball bearings, and at any speed over about 30mph was not comfortable
some mates recommended a lower tyre pressure, and WOW a different car !!
Ive gone a slow as nothing, and the tyres spin on the wheels, 12-14psi is ok on a track, but 16 psi on the road seems to be ok!
Bent Wrench
| posted on 20/1/14 at 01:12 AM |
Castor settings?
Castor makes the steering self centering.
Castor jacks crossweight to help against pushing on corner entry. Also it jacks crossweight the other way to assist when counter steering.
Castor downside is increased steering effort
[Edited on 1/20/14 by Bent Wrench]
RickRick
| posted on 20/1/14 at 06:51 AM |
make sure you have droop in your front suspension jack it up at the front, if the front wheels lift up right away thats your problem should eb
able to lif tthe car 2 inches ish before the wheels leave the floor
Davidthomas
| posted on 20/1/14 at 06:43 PM |
I think this is the print out for tracking.
Just checked my tyres pressures too. Rears were 26psi and the fronts were 18. Set them all to 16psi and hopefully the weather will allow me to have
another run out this weekend.
Thanks again for the replies!!
[Edited on 20/1/14 by Davidthomas]
