JohnH
| posted on 26/6/14 at 10:00 PM |
Wheel spacers......
Just wanting to find out if you can fit wheel spacers and get a 7 through an sva ? If so, do they have to be round ones the same size as the hubs or
can they be multi fit spacers ? Hope someone can help.
leon51274
| posted on 26/6/14 at 10:26 PM |
I passed iva with round spacers no probs, in fact the only thing he looked at around the wheel area were the studs and wheel nuts.
ali f27
| posted on 26/6/14 at 10:58 PM |
sure mine passed with multifits
snapper
| posted on 27/6/14 at 06:10 AM |
If spacer is thin you can get away with standard studs but anything 10mm or over would need longer studs fitting
I eat to survive
I drink to forget
mcerd1
| posted on 27/6/14 at 07:27 AM |
how thick do you need them to be ?
if they are much over 5mm I'd want hubcentric ones with longer studs...
the rough rule of thumb I use for the thread length is you should be able to screw the nut on by the same distance as its nominal diameter + 1 or 2
threads
so using ford M12x1.5 studs, 12/1.5 =8 full turns + a couple gives a minimum of 10 full turns of the nut
[Edited on 27/6/2014 by mcerd1]
