westf27
| posted on 19/4/06 at 09:44 PM |
The 6 P's
Perfect preparation prevents wee poor performance.Failed SVA today on stupid little points thrashed to death on here and should have been sorted on
final checks,half a days work max.
Still,need your help,Tiger silencer (new) on 2L Pinto 103db! needs to be max> 101db.Is this common,could engine tune cause this if so what to
check?Dare i ask if these silencers are good.All offers appreciated.
Chippy
| posted on 19/4/06 at 10:37 PM |
Can't you put an exhaust restrictor in the line, that should do the trick. Then take it out after SVA. atb Chippy.
westf27
| posted on 19/4/06 at 10:51 PM |
sounds good where to obtain
Danozeman
| posted on 20/4/06 at 06:19 AM |
Is it repackable? If so could u not ram some more wadding in?
Dan
Guinness
| posted on 20/4/06 at 06:51 AM |
Once again, I have a bit of kit that has fallen off my car since the SVA. DB Killer like this one, only not so clean, a bit discoloured by heat!
New on ebay for £12 delivered, or you can borrow mine for the cost of the postage out and back. I'll need it back for my next track day though!
That's looking likely to be June. You'll be passed by then though!
Let me know if that's any good to you!
Mike
jos
| posted on 20/4/06 at 07:08 AM |
Whip the silencer off, get a pair of socks, stuff em into the inlet, pop the silencer back on and see how you get on.
Socks are sacraficial in this instance and you'll probably get at least one new pair at christmas
bimbleuk
| posted on 20/4/06 at 09:37 AM |
You could check the exhuast wadding as too tightly packed will inrease the dB.
I've had good results from using half an inch of wire wool surrounded by a loose wrap of ceramic felt matting.
Car Builder Solutions do a very reasonable packing bundle for 5" or 6" inch cans.
DavidM
| posted on 20/4/06 at 11:58 AM |
Can you tell us what you failed on, just so I can check I've got those bases covered.
Proportion is Everything
iank
| posted on 20/4/06 at 01:04 PM |
Well if they are sold as bolt on SVA compatible silencers for the 2L pinto then no they aren't good by definition really. 103dB is a long way
from 101dB (log scale means 104dB is twice the sound intensity as 101dB!)
The revs you tested at will affect the reading, what was yours tested at?
Exhaust restrictor is a cheap hack that should get you through, but at some point the SVA testers will get wise to them.
| posted on 20/4/06 at 02:06 PM |
dBA's are a slightly odd scale, you actualy need a 10dB increase for a perceived doubling of loudness. The same scale also attempts to
take into account the non-linearity of the human ear, so at high and low frequencies you need more sound pressure to achieve the same dBA rating than
at the mid-frequencies.
jos
| posted on 20/4/06 at 02:25 PM |
sacraficial socks sacraficial socks
| posted on 20/4/06 at 02:26 PM |
Would look bad failing again for having flaming socks being projected out of the exhaust though
iank
| posted on 20/4/06 at 02:51 PM |
Agree, which is why I carefully said sound intensity, rather than loudness.
But I don't think it makes a lot of difference for car exhast systems since dbA rolls off very sharply below 1kHz and to a lesser extent above
10k - so anything but a screaming BEC is going to be soundly in the middle of the 0dB (or worse) part of the dBA filter. So dB is more or less the
same dBA in the range we are interested in.
http://www.phys.unsw.edu.au/~jw/dB.html#absolute
