Author: Subject: It lives!!! Hooray!!!
chrsgrain
posted on 14/5/06 at 06:19 PM Reply With Quote
Spent all weekend on the car... getting everything ready for the big key turning moment .... eveything went pretty smoothly, once we remembered to connect up the fuel pump
A temporary problem with the oil pump not wanting to prime..... and then
IT WORKS!!! Lots of sparks, smoke and noise - I want to leave it without an exhaust - it sounds great!!
Thanks for eveyones help on here, often with very dullard questions... just got to build the car up round it now!
Chris
PS anyone know how to set the idle on a standard XE??
[Edited on 14/5/06 by chrsgrain]
posted on 14/5/06 at 06:23 PM Reply With Quote
There are a few major milestones when building a car:
When it rolls on its wheels and you can sit inside and go broom-broom.
When the engine starts - suddenly it's a real car.
When it's finished and ready for the SVA.
Registration & out on the road for the first time.
Every one of these milestones gave me a great feeling!
Have fun,
Krismc
posted on 14/5/06 at 06:32 PM Reply With Quote
i was sitting inside going broom broom today!
and you are right what a great feeling!
all the best your builds!
Danozeman
Welldone mate. Great feeling isnt it!!
What fuel and ign system r u running?
Dan
chrsgrain
posted on 14/5/06 at 06:37 PM Reply With Quote
Its a completely standard XE, no bells or whistles at all. Only internal change is a rebuilt bottom end with ARP conrod bolts. Outside is some powder coat and bead blasted bits.... oh and a 'power cap' so its fits under the bonnet!
see here.... click for a bigger picture.
Chris
blockhead_rich
posted on 14/5/06 at 08:05 PM Reply With Quote
My car was also fired up for the first time today (with a lot of help from Brian aka BKLOCO!!!! so thanks for that).
Certainly put a smile on my face. Better get the brakes working now I guess.
Rich
omega0684
posted on 15/5/06 at 09:31 AM Reply With Quote
can you start the engine without having the exhaust on then? what effects would this have on the engine?
Danozeman
posted on 15/5/06 at 09:37 AM Reply With Quote
It should be controlled by the ecu. There is an idle control valve on the inlet side of the block under the manifold. Is that still there and functioning??
I dont think a standard XE will idle without it and they get full of crap and stick making them idle all over the place..
If u havent even got the exhaust manifold on it i wouldnt worry about idle untill uv got the exhaust sorted.
Engines will run without an exhaust but therel be sparks and flames and no back pressure so may not run very well.
Dan
James
posted on 15/5/06 at 09:59 AM Reply With Quote
Don't see why not, I did.
You've just got to be careful what you melt with the flames that come out of each port!
I wouldn't suggest doing it for long as you'll go deaf and your neighbours will lynch you! Oh, and do it outside where you won't get carbon monoxide posisoning.
James
Anyone got that
