Author: Subject: Coil Leaking Oil ?
pajsh
posted on 27/8/06 at 04:59 PM Reply With Quote
Coil Leaking Oil ?
Guess this might seem a bit of a numptie question but been out for a blast and my coil seems to be leaking oil?
I never considered what was inside other than HV/LV windings.
Does a coil have oil in it???
If so I guess it's time for a new one. Got home fine but probably won't go out again until I get a new one.
Still can't believe it's got oil in it.
I used to be apathetic but now I just don't care.
posted on 27/8/06 at 05:06 PM Reply With Quote
Yep - they sometimes use oil to help with cooling. Try not to get it on your skin as some cooling oils used in electrical things can be quite nasty. (PCBs).
I would only expect it to leak if it's suffered some abuse - got overheated, or it's a 9v coil running on 12v, or it's been left with the ignition on and the engine stopped (points system only).
pajsh
posted on 27/8/06 at 05:10 PM Reply With Quote
Mmmmmm guess it must be heat then.
I'm pretty sure it's the original Sierra coil and so voltage difference should not be an issue and I disconnect the battery when I'm not using the car.
It is pretty hot in there so I may have to look closer at cooling.
Confused but excited.
posted on 27/8/06 at 05:11 PM Reply With Quote
I'll second that.
I don't know what is used in a coil, but some electrical equipment has what appears to be oil and is in fact chlorinated arsenic, trade name 'Arachlor'. Very nasty sh1t.
posted on 28/8/06 at 05:30 PM Reply With Quote
The one we blew up only had oil in it . Don't use standard coils on electronic ignition, it's very messy.
posted on 28/8/06 at 05:47 PM Reply With Quote
Many of these oils can be PolyChlorinated Biphenyls (PCBs) - carcinogenic, and give off dioxin if burnt. Very nasty!
But no need to get neurotic - minimise contact with the oil, and wash your hands well afterwards. Chances are they won't be PCBs anyway.
posted on 28/8/06 at 11:30 PM Reply With Quote
oil indeed, best keep quiet about it coz as soon as Bush hears about it, he'll be invading!
probably same/similar stuff use in HV transformers - pcb and all that - nasty.
helps cooling and for h.voltage insulation.
best buy a new one
posted on 29/8/06 at 10:41 AM Reply With Quote
just a thought, but is your coil mounted vertically? I've seen several builds where paople have mounted the coil horizontally, which I've always thought is encouraging the thing to leak. There must be a reason why manufactureres always fitted the coils upright
