Toady1
| posted on 12/3/07 at 01:20 PM |
bec prop mounting
do i have to mount my centre bearing on the drivers sidewall? cant i put it on the floor position where the type9 box would have been mounted? Ive got
my engine in the bay now on wood blocks, but not too sure if its in the right postion. I could really do with seeing abother blade engined mk engine
bay.....
jimgiblett
| posted on 12/3/07 at 01:30 PM |
Mine is mounted on the bottom albeit not an MK.
Pics
here
and
here
and centre bearing support
here
- Jim
stevec
| posted on 12/3/07 at 05:41 PM |
Prop centre mtg will go on the centre tunnel on the drivers side.There was two holes there for it on my chassis.
Steve.
| posted on 12/3/07 at 05:55 PM |
The Sierra centre bearing may be too wide to fit in the bottom of the tunnel. Mounting it on the side gives a better angle for the front half of the
propshaft from what I have seen of them.
roadrunner
| posted on 12/3/07 at 06:59 PM |
Just been looking on your archive Stevec, was the two holes on the upright where the tunnel starts to widen.
Brad
Toady1
| posted on 13/3/07 at 01:17 PM |
Steve.
I dont hink i have them as ive got the older type chassis. So ill need to weld another bit of steel to the chassis to fit it.
Pezza
| posted on 13/3/07 at 01:56 PM |
Same for me, I bought mine part built.
Owner was putting a zetec in, but I soon sold that in favour of the r1 lump.
Mk Sent me a plate to weld in, but I might do it on raised brackets off the gbox mounts like jimgiblett's pics.
You couldn't pwn your way out of a wet paper bag, with "PWN ME!!" written on it, from the "pwned take-away" which originally contained one
portion of chicken tikka pwnsala and the obligatory free pwnpadom.
