Author: Subject: Shock operating range?
blueshift
posted on 9/12/07 at 01:16 PM Reply With Quote
I am making up the brackets for my rear suspension at the moment, using the GTS shock kit.
Should I be setting things so that normal ride height leaves the shock at half its range of operation? Or leave more for compression.. or what?
ta
posted on 9/12/07 at 01:32 PM Reply With Quote
Normally fully closed is with the bump stop squeeezed to 50% of its thickness.
Just be aware of the limits of articulation of the transit drag link -- varies from different suppliers
t.j.
posted on 10/12/07 at 08:06 AM Reply With Quote
Sorry braking into this topic.
I have 13"spaxes which can move 55 mm
As the bumpstop is around 30 mm a can say 70 mm is the movement?
So if the movement is 70 where should I aim for?
1/3 for drop and 2/3 for bump?
Thanks for the advise....
blueshift
posted on 10/12/07 at 07:58 PM Reply With Quote
No problem, that's the question I'm still hoping for an answer to..
Bob C
posted on 10/12/07 at 10:20 PM Reply With Quote
Folks usually say sit 1/3 way up "loaded".
(ie twice as much bump travel as droop)
Bob
blueshift
posted on 10/12/07 at 11:30 PM Reply With Quote
Sounds good. worth knowing before I set my brackets in stone! (or steel)
