RK
| posted on 11/10/08 at 02:32 AM |
general wiring question
Should the wires coming out of a premade loom and fuse box be live, unless otherwise routed through a switch?
The wire for the rad fan was through a prewired relay, fuse and switch (same switch as for the fuel pump and ignition), and it worked as I thought it
would. Surprised me that one!
The wires for the gauges, signals and brake lights seem to indicate no power when tested using a multimeter (using the instructions from CKC
magazine).
Also, does anyone know what all the wires are from a Lucas indicator switch? There are several green and yellow striped ones, and one black one.
big_wasa
| posted on 11/10/08 at 07:32 AM |
You will have switched live and permanent live.
Perm= Hazard, Horn, Fan, side lights ect.
Switched= Main lights, Indicators ect
RK
| posted on 12/10/08 at 12:44 AM |
OK: when things were checked with the multimeter prior to connecting wires, the fuses were all right. When they were connected, no power. I was
blowing the fuses because I accidentally touched the wires to the chassis, shorting the circuit. What a dummy. New fuses, and everything works.
