Author: Subject: sva forms
A1
posted on 3/11/08 at 02:58 PM Reply With Quote
sva forms
which forms do you need for the test? just the ministers approval application (sva 1) ?
is there any other paperwork needed?
cheers!
Mr Whippy
posted on 3/11/08 at 03:17 PM Reply With Quote
take along - pics of the build so you can show the inspector how you built it
proof of engine year if needed for emissions
Mot if you have one already
some paper money to bribe inspector/picture of him in bed with his mistress if the bribery fails...
robinj66
posted on 3/11/08 at 04:41 PM Reply With Quote
If you're talking about applying for the SVA then you need SVA1 and the Amateur Built Declaration (both found on Vosa site) plus your payment (£190) all of which are sent to Vosa @ Swansea.
They will also want copy receipts and build pictures showing the major components (brakes, axles, steering, engine, transmission, chassis & body) to prove that it is indeed an amateur build , even though you have just declared that on the aforementioned form
Ben_Copeland
posted on 3/11/08 at 06:22 PM Reply With Quote
Do you need to put a copy in with the sva forms? or do you take it to SVA?
Ben
Locost Map on Google Maps
Enter Your Details Here
robinj66
posted on 4/11/08 at 08:53 AM Reply With Quote
Receipts and pictures should be sent with the forms.
You may also need to have build pictures available at the test to show those areas which are no longer accessible.
omega 24 v6
posted on 4/11/08 at 12:51 PM Reply With Quote
Has anyone sent/ does anyone know if a cd with all your build pics (300 plus) would be acceptable or do you need to select some and print them off.
Ben_Copeland
posted on 4/11/08 at 06:51 PM Reply With Quote
Hmmmm i'll have to start making some up then
[Edited on 4/11/08 by Ben_Copeland]
Ben
