<<  1    2  >>
Author: Subject: Opinion - Best sounding 4 cyl engine - and why?
Spyderman
posted on 27/2/06 at 02:00 PM Reply With Quote
For a four banger it has to be a flat four for sound quality. However only above about 1500 rpm's. Below that and they all sound like Beetles.
It must be the offset firing order with the slight pause between the pairs that makes it special. If you can get them to rev high enough it is just music! Hence the Alfa Sud as one of the best ever sounding small cars.
All in my humblest of opinions of course!
Terry
Spyderman
locost_bryan
posted on 27/2/06 at 11:12 PM Reply With Quote
I've always hated the flat-four throb - always sound like they've dropped a cylinder. otoh, a Subaru WRC at full noise sounds superb
Always liked the DOHC Chevette HS2300 (but then it's supposed to be half a small-block Chevy)
Bryan Miller
Auckland NZ
Bruce McLaren - "Where's my F1 car?"
John Cooper - "In that rack of tubes, son"
akumabito
posted on 28/2/06 at 07:44 AM Reply With Quote
Does a 4-plate Rotary engine count?
John.Taylor
posted on 28/2/06 at 12:48 PM Reply With Quote
3.0 Alfa V6
My brothers pride and joy is a 1998 GTV 3.0 V6 that we took to Le Mans last year. The sound through the gears all the way to 140 from the toll booths was spectacular. The whole car feels highly stressed all the time, even just pottering about the engine is straining at the leash. I Can't see how these engines last more that 50k miles!
A friend had a Clio Williams MK1 that was standard but for a K&N filter. The engine sucked so hard it sounded as if it was supercharged!
Also had a blast from the past last week when a BMW E30 2.5 Sport hammered it past me on full song!
sgraber
posted on 28/2/06 at 03:11 PM Reply With Quote
V10 eh? that's cool.
Would I be correct in assuming that most of the engines mentioned here are of the 10:1 and above compression ratio? The thought being that the hi-comp engines make a much lovelier bark than the low comp ones?
Originally posted by andyps
.. but the Gallardo is a V10, ...
Steve Graber
http://www.grabercars.com/
"Quickness through lightness"
NS Dev
posted on 28/2/06 at 03:27 PM Reply With Quote
Yea, most are higher compression, BUT!
Most of the lovely noise is intake not exhaust, and is down to cam timing+individual runner induction per port!
If you listen to the "Mancona" on the first vid I posted, all you can hear as is comes towards you is induction noise, it's only once is has passed the camera that you can even hear the exhaust at all.
Dale
posted on 28/2/06 at 03:56 PM Reply With Quote
An alloy flywheel makes a difference on the sound of throtle blips. So you get that nice idle to redline and back to idle in a partial second.
Dale
Dale
my 14 and11 year old boys 22
and 19 now want to drive but have to be 25 before insurance will allow. Finally on the road
<<  1    2  >>
