Author: Subject: Fuel flow damper and pump issue
dr-fastlane
posted on 17/1/09 at 09:43 AM Reply With Quote
Fuel system issue
I’m running a 2.0 Sohc EfI sierra engine and it has a intank fuelpump from a Dohc engine. With my new fueltank I want a external fuelpump. What type pump can be used? And what are you using?
In the Haynes sierra service and repair manual, there is a picture of a fuel damper mounted right at the fuelpump outlet. Do we need that?
[Edited on 17/1/09 by dr-fastlane]
I have not failed once. I have successfully found ways that will not work!
https://www.motor-forum.nl/threads/hardtail-dragstyle-project.343482/
mark chandler
posted on 17/1/09 at 07:01 PM Reply With Quote
This will do you, EFI pump barbed ends so easy to connect in.
You do not need the damper.
I got one off him last week, arrived next day so recommended by personal experience.
[Edited on 17/1/09 by mark chandler]
