Author: Subject: Is it OK to join 8 mm copper tube for fuel lines?
AdrianH
posted on 1/4/09 at 08:53 PM Reply With Quote
I am struggling getting the copper fuel lines in place trying to do bends in situ and get around gearbox and diff.
I know it could be done if I take the engine etc back-out but that will be a big job. What is the consensus on joining the copper tube as you would do for water pipe with a soldered coupler?
Is it permissible?
My other option is to run braided fuel line through the tunnel and fasten that at regular intervals.
I have two runs to do.
Adrian
Why do I have to make the tools to finish the job? More time then money.
omega0684
posted on 1/4/09 at 08:55 PM Reply With Quote
as long as you use marked fuel pipe and fuel clips its fine.
flak monkey
posted on 1/4/09 at 08:57 PM Reply With Quote
Soldered joints will be fine as long as there are no pin holes.
Sera
http://www.motosera.com
snapper
posted on 1/4/09 at 08:58 PM Reply With Quote
As long as you do a good job it should be fine, however i don't know how the vibration would affect the joint or the presure if its fuel injected.
You could use a hand pipe bender to help with the dificult bends or if you do solder joints then some rubber fuel pipe over the joint and clipped with the proper pipe clips would be both leak and vibration proof.
I eat to survive
I drink to forget
AdrianH
posted on 1/4/09 at 09:15 PM Reply With Quote
One of the things that surprised me was some lengths of fuel pipe from the donor sierra seemed to be plastic!!
The system is not injected so pressures are virtually none existent.
I do have a small hand held tube bender but the issue is getting a one piece length of pipe around every thing and in place to do the bends. Using 100 mm centers for the nylon clips to secure the fuel lines, or that is the plan so should be OK reducing vibration. I think I will try it tomorrow.
Thanks for the answers
Adrian
Antnicuk
posted on 1/4/09 at 09:16 PM Reply With Quote
just use rubber fuel hose for the awkward bits, its what manufacturers do.
600 BHP per ton, Stylus Brought back from the dead! Turbo Rotary Powered!
Danozeman
posted on 1/4/09 at 09:34 PM Reply With Quote
I bent mine in situ. If you bend copper pipe alot it will work harden and it will be a pain to bend. Could this be why u are having trouble?
Dan
AdrianH
posted on 1/4/09 at 10:38 PM Reply With Quote
Hi Dan. It is new copper pipe and not bending it in the same places repeatedly. Just have about 9 bends. Goes over drivers side bell housing, crosses tunnel, drops down to floor , along bottom of tunnel passenger side, under diff to prop ring crosses back to drivers side, then out under diff into wheel area then bend outward and up to where I can join with rubber tube to tank.
The convoluted route is to keep away from reversing switch and where the speedo cable will be. Also waning to keep the drivers side of tunnel clear so that I can remove side panel and get to prop shaft and do any maintenance work from that side.
The carburetter is on the drivers side and so is the petrol tank supply and return.
It just a ball ache working with around 2.5 metres of tube in such a small area.
Adrian
RoadkillUK
posted on 2/4/09 at 01:14 AM Reply With Quote
We did the same as above, used some rubber fuel hose, also good for replacing squashed pipe.
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
AdrianH
posted on 2/4/09 at 06:28 AM Reply With Quote
RoadkillUK
Did you flare out the 8 mm copper pipe when you joined against rubber, and if so how?
Adrian
designer
posted on 2/4/09 at 07:46 AM Reply With Quote
I would not put a soldered joint on a copper fuel line.
tomgregory2000
posted on 2/4/09 at 08:07 AM Reply With Quote
Compression joints as used on gas fittings
SteveWalker
posted on 2/4/09 at 09:34 AM Reply With Quote
You don't need to flare the end of the copper pipe, just solder an olive on.
posted on 2/4/09 at 11:10 AM Reply With Quote
Why? (purely out of curiosity)
posted on 2/4/09 at 11:16 AM Reply With Quote
Does anyone know of a source for this stuff?
I'm thinking of replacing my copper tube (8mm central-heating grade). I think that it's too thin and fragile, and was never intended for use in the harsh vibrating environment used in a car. It also kinks and dents far to easily for my liking, especially considering that it runs along a few inches from the propshaft!
I have used rubber pipe in the past - it got replaced when I spotted that it had perished badly after just 2 or 3 years of use. It's possible that it wasn't a suitable grade for madern unleaded fuel, but now I'm wary of it.
I see 2 possible alternatives - 5/16" (8mm) kunifer brake tubing, which is very tough and has a respectable wall thickness.
Otherwise there's the manufacturer's type plastic tubing - if I could find it.
posted on 2/4/09 at 05:36 PM Reply With Quote
I originally used a plastic fuel pipe when I built my car as it was running a carb . I managed to get some from a mate who runs a hydraulics company . It is now used as the fuel return for my injection system . Most modern cars seem to use plastic fuel pipes even the high pressure pipes.
RoadkillUK
posted on 2/4/09 at 07:52 PM Reply With Quote
RoadkillUK
Adrian
Hi, nope we didn't do anything with the end other than clean it. The copper pipe will go into the rubber pipe as far as you like to push it. We're running carbs so there's no real pressure, but I can't see it being a problem if there were pressure.
Roadkill - Lee
www.bradford7.co.uk
AdrianH
posted on 2/4/09 at 10:26 PM Reply With Quote
OK thanks again for the responses,
I am going for a soldered joint in the tube, the clips are every 100 mm apart so will keep it firm, I have plenty of flux and extra solder to ensure I get good capillary action.
Hope to get this task finished soon as it is driving me nuts working in the cramped space. Certainly is one of the jobs that should be done before the engine, gearbox and diff go in place.
Adrian
