Author: Subject: ZX12R 1st start up checklist?
eznfrank
posted on 20/5/09 at 08:35 AM Reply With Quote
The missus is away all weekend and I've taken Friday off work so I've got a full 4 days in the garage all to my self - woohoo .
Anyways, I'm aiming to get the engine (ZX12r) fired up this weekend and wondered if anyone had a few handy hints for checking before I go ahead?
Here's what I've got so far:
* Cooling systems all plumbed in but not filled
* The engine loom is fairly un-molested albeit re-directed so I don't envisage any massive problems there.
* I've got the original ignition barrel so no resistors to worry about.
*Battery is to be filled and charged yet but I guess that'll only take 24 hours?
* Fuel to be filled
* Oil to be filled and filter changed
* Turn over by hand a few times first
* Fire Extinguisher on standby
* Make sure it's in neutral
I'm sure ther's loads for me to add to this?
ETA - I'll pick up a new set of sparkplugs too I think.
[Edited on 20/5/09 by eznfrank]
handyandy
posted on 20/5/09 at 08:45 AM Reply With Quote
video camera to record the major event.
andy
l0rd
posted on 20/5/09 at 08:51 AM Reply With Quote
Don't you need to try starting it without spark plugs on in order to build up oil pressure?
flibble
posted on 20/5/09 at 09:01 AM Reply With Quote
Although mine was a car engine so maybe different, this is what I was worried about last week when I started mine.
I turned it over with the sparkplugs in but unplugged (and fuel, ecu etc.) thinking that would be enough but after 3 or 4 30 second bursts the pressure was still barely registering. I took the plugs out and after a couple of 10 second bursts the pressure went up to where it should be so I'd say this was a good plan of action
I had a raft of fire extinguishers with me too, its surprisingly scarey but great when you hear it go!
Good luck! It'll be fine
posted on 20/5/09 at 09:43 AM Reply With Quote
You're not far off mate...
Plugs out and turn over first... get the Oil flowing, it always goes better with a bit of lube first
Definately the Video Camera needs to be out - set on a wide angle to capture your look of joy!
Good luck and let us know how it goes...
S
posted on 20/5/09 at 09:51 AM Reply With Quote
Prepare for the stupid ear to ear grin when it fires up and your collection of parts becomes a living, breathing beast
Will you be able to move it under it's own power or is that further down the line...?
eznfrank
posted on 20/5/09 at 09:56 AM Reply With Quote
Yeah I could possibly move it, just need to bleed the brakes but I'm in no rush to do that just yet.
Any sparkplug recommendations from the BEC folk on here?
Richard Quinn
posted on 20/5/09 at 11:04 AM Reply With Quote
Tissues, especially if it starts first time.
(err, just me then?)
MikeCapon
posted on 20/5/09 at 11:06 AM Reply With Quote
Clutch/sidestand safety cut-outs?
posted on 20/5/09 at 11:11 AM Reply With Quote
How do you do this ? I can't find a way with my bike unless you push it in gear with the ignition off. Don't buy dear spark plugs till you have it running properly as the iridiums and platinums don't like flooding and will not clean up to be reused like standard plugs.
eznfrank
posted on 20/5/09 at 11:12 AM Reply With Quote
Yeah, I've connected both the side stand and clutch to earth which is the correct position according to the Kwak wiring diagram. I've left neutral for now but might change it later if it's winding me up.
Not touched the bike down switch yet but doubt that will affect it at this stage?
eccsmk
posted on 20/5/09 at 11:44 AM Reply With Quote
you will also need an audience
and a large celebratory drink!!
best of luck mate (dont forget the video)
mr henderson
posted on 20/5/09 at 02:07 PM Reply With Quote
Ear defenders, you will need thoses, especially inside a garage.
John
