Litemoth
| posted on 26/6/09 at 08:56 PM |
Sierra Diff Stripdown & Rebuild
I need to change the seals and clean out the bearings on the Sierra diff ( 7" ) before I mount it. Anyone have a guide on it?
[Edited on 26/6/09 by Litemoth]
GrumpyOne
| posted on 26/6/09 at 09:12 PM |
There is a sierra diff guide here amongst other things, don't know how good it is.
http://www.siipicossu.com/manuaaleja/manuaalit.htm
Colin
My wife is very understanding, she understands that if I am in the garage I am not in the house annoying her.
stevegough
| posted on 26/6/09 at 09:53 PM |
I remember seeing a thread on here asking the same question about 2 months ago - the concensus seemed to be - don't bother - the strip down
requires the use of a number of 'special tools' and is very 'ahem' DIFFicult.
Do a search - there were quite a lot of replies.
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
GrumpyOne
| posted on 26/6/09 at 10:06 PM |
This one is for the Scorpio but shows the special tools required.
http://www.fordscorpio.co.uk/manual/rearaxle/DiffOverhaul.pdf
Colin
austin man
| posted on 26/6/09 at 11:41 PM |
changing the seals is easy if yur going to remove the bearings you may as well change the. If you go this route contact your nearest bearing and seal
supplie and give them the numbers on the seals you will save a fortune if you go via the manafacturer.The saving on 2 cam seals local factor vs
manafacturer saved £12.00
Litemoth
| posted on 27/6/09 at 12:44 PM |
Thanks fellas. Can't download the guide mentioned above though although do have the Granada one. Here goes then.......
