Author: Subject: DOES ANYONE KNOW WHAT THIS SIERRA DIFF IS?
tomblyth
posted on 30/9/09 at 09:32 PM Reply With Quote
TAB ON DIFF SAYS?
83 bg4006kc 4 314 6j26,
HAVE READ SOME THEADS ON HERE BUT STILL IN HE DARK ! COULD ANYONE HELP!
Isn't it a 3.14 diff???
ReMan
posted on 30/9/09 at 09:37 PM Reply With Quote
It's useless.
I'll take it off your hands fo £50
Ben_Copeland
posted on 30/9/09 at 09:43 PM Reply With Quote
looks like a 3.14...
Ben
Locost Map on Google Maps
Enter Your Details Here
Dingz
posted on 30/9/09 at 09:45 PM Reply With Quote
No wonder you are shouting!
went on and on.
posted on 30/9/09 at 09:49 PM Reply With Quote
Hi Tom, I'll swap you for a 3.62 if thats what your after...
tomblyth
posted on 30/9/09 at 09:54 PM Reply With Quote
so its is a 3.14 (good) whats the rest of the numbers mean?
Ben_Copeland
posted on 30/9/09 at 10:00 PM Reply With Quote
Does it matter lol
You have the best bit lol
Ben
Ben_Copeland
posted on 30/9/09 at 10:02 PM Reply With Quote
http://www.locostbuilders.co.uk/viewthread.php?tid=85080
Might give you some info
Ben
omega0684
posted on 30/9/09 at 10:27 PM Reply With Quote
not an LSD though
flak monkey
posted on 1/10/09 at 06:46 AM Reply With Quote
not an LSD though
They didnt make them in lsd. The only std LSD's were 3.62 and 3.92 in the cossies
But yes defo 3.14
Sera
http://www.motosera.com
Gergely
posted on 1/10/09 at 07:12 AM Reply With Quote
83 BG is the prefix of all diffs in the 82 to approx. 87 model years. 4006 is the same on all seierra diffs, KC is the important bit, only the 3.14 push-in type diffs had this code, and 314 is obviously the ratio. The rest is serial No.
Double check the ratio by counting the number of propshaft rotations required for one full driveshaft rotation. If it is 3 rotations + 50 degrees (less than a quarter of a rotation), and the diff is not welded, you can make some money... or use it in your BEC... :-)
Gergely
Our build pictures
fesycresy
posted on 1/10/09 at 08:00 AM Reply With Quote
Take the back off and in white pen writing you'll see the magic numbers.
I bought a 3.14 but wouldn't hand over the cash until I took the back off.
3.14 tags are worth a few quid
mangogrooveworkshop
posted on 1/10/09 at 10:56 AM Reply With Quote
314 swop you for a lsd........much better in the car.....lol
