Author: Subject: how much propshaft overlap?
nib1980
posted on 12/10/09 at 10:57 AM Reply With Quote
hi all,
i'm in the process of changing to a 4age engine and gearbox.
my problem is the new gearbox won't fit as far back as the old one for various reasons.
I got a propshaft with the package, but with the gearbox in the furthest back position i can, I maybe only get 50% of the splined section in contact. (between the front of the prop and back of the box.
is this acceptable?
if not i got major issues, probably involving a new longer propshaft
another annoyance to add to my list
tegwin
posted on 12/10/09 at 11:02 AM Reply With Quote
I would want as much of the spline in contact as possible (allowing for a bit of play if the diff/gearbox moves)
Rather than buying a longer prop could you make/have made a spacer to sit between the prop flange and the diff? Cant imagine it would need to be very long?... Just might be cheaper than a new shaft.
www.verticalhorizonsmedia.tv
Mr Whippy
posted on 12/10/09 at 11:04 AM Reply With Quote
I do it like this –
If you jack the rear of the car up and let the suspension hang down, then check to see if the shaft still has at least a couple of inches of it still inside the gearbox, then jack the suspension back up till its at the bump stops (weight in the car will be needed unless you remove the springs) and check the propshaft has about 10mm before it binds. If that’s all ok then I’d be happy with the propshaft length.
blakep82
posted on 12/10/09 at 11:07 AM Reply With Quote
Originally posted by Prop Man
Hello
As standard we leave 25mm of spline showing from the gearbox seal.
It is ideal to have at least 70mm of spline engagement.
taken from http://www.locostbuilders.co.uk/viewthread.php?tid=117027
i think that related more to type 9 boxes, but think its still the same
________________________
