Author: Subject: what fuel pump/reg with zx6 carbs
JAMSTER
posted on 22/10/09 at 06:06 PM Reply With Quote
what fuel pump and reg do you use with zx6 bike carbs pinto 1.6 please dont laugh about engine and size trying to do it as cheep as pos to start with
cd.thomson
posted on 22/10/09 at 06:08 PM Reply With Quote
hi mate,
try and use the matching bike pump or one from a similar bike,
generally works out cheaper, you know its going to work and you dont need a pump and regulator
Craig
roadrunner
posted on 22/10/09 at 06:09 PM Reply With Quote
If you want cheap then any bike fuel pump will do. The best thing about a bike pump is that it keeps pushing fuel through until it can feel a resistance then it slows down to required fuel rate.
whitestu
posted on 22/10/09 at 06:19 PM Reply With Quote
ZX6r pumps go fairly cheap on ebay - £20 or so.
Stu
Stuart_B
posted on 22/10/09 at 06:49 PM Reply With Quote
i just used the the bike fuel pump, as they are self regulated. mine cost £15.
no need to laugh i have the 1.6 pinto on cbr600fx bike carbs, it pulls good.
stuart
JAMSTER
posted on 22/10/09 at 06:56 PM Reply With Quote
do you do anything with the tps
cd.thomson
posted on 22/10/09 at 08:03 PM Reply With Quote
tps and the fuel pump? no they dont work together.
the tps sensor can be used with an ignition control unit like megajolt.
Craig
cryoman1965
posted on 22/10/09 at 08:05 PM Reply With Quote
You can use the pinto fuel pump without prob. I have gsxr600srad carbs on 2.0ltr. I left the TPS on but not used. Poss to change to mega jolt later if required.
Nige
Danozeman
posted on 22/10/09 at 09:50 PM Reply With Quote
Bike pump is best. No need for reg then. See my for sale thread
The tps is only needed for 3d ignition mapping otherwise just leave on not connected to anything.
Nowt wrong with a 1.6 bud.
[Edited on 22/10/09 by Danozeman]
Dan
