Author: Subject: Where to get a short section of 28mm Silicone Flex hose ??
Tris
posted on 3/4/10 at 09:35 PM Reply With Quote
Hi all,
Ive got a little problem with my new radiator install, in that ive not got room to fit a 28mm to 32mm reducer at the bottom of the rad, to then onward connect to the rest of the car. (the car is all in 32mm but the radiator has 28mm fittings).
Does anyone know where i can get a small 8inch section of ID 28mm flexible silicone pipe and a small bit of OD 28mm tube to use as a connector ?
All the ebay sales are for 1 meter, which i am a bit loathed to buy as i only need a small section (as its quite expensive stuff).
Tris
[Edited on 3/4/10 by Tris]
blakep82
posted on 3/4/10 at 09:41 PM Reply With Quote
i know its not 8 iches long, but can you do anything with one of the coupling hoses? or if it needs a bend, how about a 45 degree bend? you can always cut the bend out, should give you a bit about 4" long?
________________________
Tris
posted on 3/4/10 at 09:45 PM Reply With Quote
It needs to bend about 20-30degrees unfortunately, so ideally i was after some flex. Its just so dam expensive (£30)
I have found an alloy coupling on ebay just, so thats sorted. Just need to find a short length of flex now.
blakep82
posted on 3/4/10 at 09:48 PM Reply With Quote
i was needing to buy a meter of flexi stuff, but mine would be 35mm i think.
big_wasa
posted on 4/4/10 at 08:43 AM Reply With Quote
I have some 32mm
NS Dev
posted on 5/4/10 at 09:37 AM Reply With Quote
"mrsilicone" on ebay, really cheap and great service, about £8 for that sort of bit
NS Dev
posted on 5/4/10 at 09:38 AM Reply With Quote
ps message them or phone them and they'll do whatever length you want, no need to buy a full metre
