ttalps2000
| posted on 1/5/10 at 09:25 AM |
Toyota 4age to Type 9
Hi
Im in the process of putting a Toyota 4age into my Stylus for the final time, which is mated to a Type 9 box. I have the bell housing already (not a
RAW one) but do not have the other relevant parts. Does anyone know what the following parts are from and part numbers if pos:
Spigot Bearing
Clutch
Spring Plate
Flywheel (have the toyota one)
Clutch release bearing
Starter
I know RAW do the parts, but having connections in the trade i can get the components at cost price.
Has anyone fitted a hydraulic clutch release bearing to this conversion before? I have the ford arm etc that came on the gearbox.
Some pics of how it all goes together would be great to if possible.
Thanks for your help.
Worzey
| posted on 1/5/10 at 11:09 AM |
Are you saying you already have a Toyota flywheel? Isn't that what you need?
I've got a 20v 4AGE flywheel lying spare in the garage. Assuming that fits you're welcome to it.
Caterham R400
rost
| posted on 1/5/10 at 01:35 PM |
I've used a SKF stock bearing as a spigot bearing, let me look up the part no.
Clutch release bearing will be the standard sierra one. There's a slight difference in thickness though, I had one that was 3mm taller and made
the clutch slip. I had to cut the hole for the clutch release arm a little bigger for it to be able to fully disengage.
Flywheel I used is the standard 20V one (hard to find because most seem to have been automatics for some reason!) Used the Toyota pressure plate
too.
Clutch plate is from a 2l? sierra I think, it's 200mm wide. (the sierra 1.6 is 190mm wide)
I can't remember from which car the starter came.
Charlie don't surf!
ttalps2000
| posted on 2/5/10 at 08:42 AM |
Thanks for the replys guys.
Yes I already have the toyota flywheel. Its a first generation 16v lump I have. I thought it would be the toyota flywheel, but wanted to check.
So I just need a sierra clutch and release bearing by the sounds of things.
If you could get that skf number for me it would be hugely appreciated.
I have a feeling that the bell housing I have is for a hydraulic clutch only. I think it was made by RM sport!? It looks quite different to the RAW
one anyway!
ttalps2000
| posted on 14/5/10 at 04:25 PM |
bump
