Author: Subject: Rover T16 to Landrover Trans?
posted on 3/8/10 at 11:20 AM Reply With Quote
I have an idea of what is involved but can any one advise or point me towards how to join a Rover T16 turbo engine to a Landrover transmission, hopefully a LT77?
The V8 is dead, long live the T16!
LG,
tomgregory2000
posted on 3/8/10 at 11:43 AM Reply With Quote
i wouldnt do it if its for your 4x4
not enough low down torque unless you are making a cross country speed machine rather than a mud monster or hill climber
posted on 3/8/10 at 12:23 PM Reply With Quote
Yep, its for the 4x4 Jago, I want to use it as its lying in the garage.. there is a zetec as well, just thought the T16 would be easier to join up.
So, any experience of joining a zetec to a LT77??
posted on 3/8/10 at 02:18 PM Reply With Quote
Parts from a 2 litre Sherpa or Disco 2litre Turbo
t16turbotone
posted on 3/8/10 at 02:52 PM Reply With Quote
You can use an LT77, ex SD1 , or a new 2wd R380. You can even use a 4x4 one if you convert it to 2wd, but it's hardly worth it...
Bellhousing is 2000 SD1, LDV400 2.0, or Sherpa 2.0 diesel. You will also need the correct engine back plate. The Disco bellhousing is meant to mate up to a big clutch housing on the back of the engine, and is a different shape
posted on 3/8/10 at 03:45 PM Reply With Quote
Any idea where I can get the bellhousing bits? Searched eblag but nothing showing there.
I have two steel back plates and flywheels left over from my Montego turbo'd Striker and have the PG1 backplate. clutch and front half of the gearbox from the donor 820.
mark chandler
posted on 3/8/10 at 04:21 PM Reply With Quote
be warned, different length first motion shafts involved above, it may not just be bell housing changes.
t16turbotone
posted on 3/8/10 at 06:02 PM Reply With Quote
It all gets a little tricky to be honest, my seven has T16 Turbo engine, SD1 2000 bellhousing, flywheel and clutch, LT77 Gearbox. Have a look at this excellent site for some good info
Tony
http://www.kewengineering.co.uk/upgrades4mgs/Engines/fitting_t_series_turbo.htm
zilspeed
posted on 3/8/10 at 06:04 PM Reply With Quote
Coozer
Do a google for a bloke called Marko Cosic. He did this conversion years ago.
Here's a link to some stuff.
http://www.cosic.org.uk/MarkoStuff/Land-Rover%20T-Series/LR%20Co nversion%20More/
