fha772
posted on 27/9/10 at 07:40 PM |
Anyone know about SD card, HD camcorders?
I'm having a bit of trouble with my camcorder that i took to the £999.
I've copied all my videos off of the SD card, but i can't delelte them off of the memory card.
It keeps saying the files are Write-Protected, then says remove the writer-protection to continue.
I now have 2 16gb SD cards that i can't re-use.
Has anyone got any ideas how i can delete the files from the cards?
http://www.ppcmag.co.uk/forum/viewtopic.php?f=47&t=6743&start=105
MakeEverything
| posted on 27/9/10 at 07:43 PM |
Theres a little switch on the SD card that write protects the contents. flick it across.
Kindest Regards,
Richard.
UncleFista
The write-protect tab hasn't accidentally been moved ?
Tony Bond / UncleFista
fha772
| posted on 27/9/10 at 07:45 PM |
Nope, tried that, it made no difference...
snapper
| posted on 27/9/10 at 07:48 PM |
If the above does not work open the SD card dialog box on your computer, look at the file info, on many you can un-protect each file then delete.
You can also re-format the card, that will delete everything
I eat to survive
I drink to forget
fha772
| posted on 27/9/10 at 07:52 PM |
How do i open the dialogue box?
I'm a bit of a computer numpty...
stevebubs
| posted on 28/9/10 at 07:59 AM |
right click file
click properties
