ko_racer
| posted on 16/10/10 at 12:19 AM |
Need to get pipe through rocker cover and keep seal
I've got to get some rubber hoses through the rocker cover on my engine but am struggling to find a way to do it to keep the oil from escaping
out the hole too.
I also need to be able to remove the pipe which needs to attach to the head under the rocker cover, so I need to be able to attach the pipe and then
put the rocker cover on afterwards.
Have thought of just a grommet, but not sure how well that would seal and if it would stand up the temperature/oil
Have tried looking for a 1/4 barb to barb panel mount, but had no luck. Can't really use any other fitting type as I don't have the space
under the rocker cover.
Ideally I would make a solid fitting to go inside the engine and seal to a hole in the rocker cover and then have a barbed take off from there but
I've not got the machinery to do this and don't know anyone who can either.
Anyone got any suggestions??
snapper
| posted on 16/10/10 at 04:42 AM |
Solid Pipe inside rocker with through panel jic fitting
Hole in rocker cover, when cover is put on jic fitting goes through hole then from outside put dowty washer/seal over then bolt for jic.
This will leave a threaded end that you can use to attach the external part of the pipe work to
I eat to survive
I drink to forget
gavin174
| posted on 16/10/10 at 06:27 AM |
if its a metal rocker cover get a piece of tube the internal diameter of pipe and braize/weld direct to the rocker cover...
or tig weld if its ally
cliftyhanger
| posted on 16/10/10 at 07:03 AM |
think automotive/mocal do all sorts of pipey stuff, including bulkead fittings. Worth a nose?
40inches
| posted on 16/10/10 at 09:51 AM |
Fuel tank fitting, near bottom of page.
