AndyW
| posted on 15/4/11 at 03:32 PM |
zetec blacktop sump?
For some reason beyond my computer skills, when ever I search for something it returns 2 million topics which bear no resembalance to what I want. So
here is my question's for the day.
1) Im using a 2.0 blacktop zetec, type 9 box and standard flywheel. What release bearing do I use and also anything else?
Question number
2) Who can modify my sump for me without it costing the price of a new kit car? (I have the standard 2.0 sump)
any help, advise, answers, suggestions welcome as I want to finally marry the engine to the box and fit it in the car some time before the next new
year........
PS If you are a skilled or semi skiled welder and can make/modify my sump, please u2u me how much you want or post if you want the world to
see........
lewis
| posted on 15/4/11 at 04:09 PM |
I would also be interested in the sump question so if you get any answers pls let me know :-)
whitestu
| posted on 15/4/11 at 04:59 PM |
I can't answer the question on release bearing as I used a 1.8 CVH flywheel and clutch, but it is worth getting a 1.8 flywheel as they are much
lighter.
2) Who can modify my sump for me without it costing the price of a new kit car? (I have the standard 2.0 sump).
You don't need to be much of a welder to do this. I just cut my sump pan so it was level and welded a flat piece of plate on the bottom. It
looses a bit of oil capacity but not much.
Stu
AndyW
| posted on 15/4/11 at 05:17 PM |
lighter.
Stu
I am not much of a welder, in fact never welded, nor own a welder
whitestu
| posted on 15/4/11 at 05:27 PM |
My point was that just about any place that does a bit of welding should be able to help you out if you cut the sump and make a plate to weld it up
with.
Stu
femster87
| posted on 15/4/11 at 05:44 PM |
if your using the standard 2.0 zetec flywheel and clutch. You can use the release cct303 bearing. This is what i used on mine. The info came from the
zetec website here
http://www.toyne.org.uk/zetec-fitment.html
fazerruss
| posted on 15/4/11 at 06:40 PM |
you also need to shorten the oil pick up pipe
"if assholes could fly this place would be an airport"
jacko
| posted on 15/4/11 at 07:55 PM |
You can buy a steel pick up pipe it makes it easier to modify
AndyW
| posted on 15/4/11 at 09:41 PM |
I think I may have not got my message accross properly. Is there anyone on here that would shorten my existing sump and pick up for me in exchange for
beer tokens?
| posted on 15/4/11 at 09:56 PM |
Is it the 2l flywheel????????????
Thinking about it
| posted on 15/4/11 at 10:02 PM |
beer tokens?
Strontium Dog on here does it.
AndyW
| posted on 16/4/11 at 06:35 AM |
Yes standard 2ltr fly wheel. Is that a problem?
dunk3
| posted on 16/4/11 at 07:42 AM |
I used this website (Zetecinsde.com) for some of the information on fitting a 2.0L zetec Blacktop to Type 9 gearbox, gives you all the information you
need.
