Author: Subject: Help with Engine Mounts
Tiger Super Six
posted on 20/6/11 at 08:33 AM Reply With Quote
Morning,
Swapped the pinto for the duratec at the weekend and it appears that the engine sits higher. Currently I have the Burtons 50mm rubber doughnut engine mounts and I know that you can buy these thinner, at 35mm. That said, I could really do with some that are 25mm thick.
What have others used, or ideas?
Thanks in advance,
Mark.
Mark
Tiger Avon
gavin174
posted on 20/6/11 at 08:52 AM Reply With Quote
Hi Mark
What about changing the donut to 34mm and then altering the engine mount that bolts to the engine
You may be able to drop it another 10mm that way
Tiger Super Six
posted on 20/6/11 at 09:34 AM Reply With Quote
Good idea and that's an option, although the mounts that I have already come out at quite a flat angle. If I tried to move them lower this would make them quite flat so I am not sure what strengh the triangulation would have.
If I can't find any thinner then that might have to be the solution.
Mark
Tiger Avon
