Norfolkluegojnr
| posted on 15/9/11 at 11:20 AM |
Mondeo/Duratec Question
All powerful/knowledgeable LCB, can you answer a question for me:
Looking at a mondeo for the wife - do all duratecs have dual mass flywheels?
Hearing about the ball ache they can cause on the TDCI models, I was thinking 2.0 petrol version to skirt the issue.
Anyone know?
Ta
karlak
| posted on 15/9/11 at 11:28 AM |
My 2 litre petrol Duratec had Dual Mass flywheel. I think the only "2 litre duratec" that doesnt is the ST150 in the Fiesta.
hth
MK Indy - 2litre Duratec - Omex 600 - Jenvey throttle bodies - ETB DigiDash2
mcerd1
| posted on 15/9/11 at 11:52 AM |
as above the ST150 Fiesta is the only one without as far as I know
also the ST150 doesn't have the EGR system either
[Edited on 15/9/2011 by mcerd1]
big-vee-twin
| posted on 15/9/11 at 12:00 PM |
The ST150 has standard flywheel and EGR blanked off as standard
http://www.triangleltd.com
Norfolkluegojnr
| posted on 15/9/11 at 12:09 PM |
dam, so no non-DMF benefit to going petrol then?
Tiger Super Six
| posted on 15/9/11 at 01:52 PM |
What problem does it cause in a mondeo?
Mark
Tiger Avon
big_wasa
| posted on 15/9/11 at 02:28 PM |
When it brakes down it buggers the starter motor.
So the garage bill is a new clutch, A new flywheel, A new starter and all the labour = One large bill.
Norfolkluegojnr
| posted on 15/9/11 at 03:16 PM |
Yep thats it. Don't want to get hit with a massive bill a few weeks/months in.
Any one got any experience of owning/driving one? when do they normally fail?
Ninehigh
| posted on 15/9/11 at 06:14 PM |
Mine's approaching 100k, all fine so far.
steve m
| posted on 15/9/11 at 06:33 PM |
Ive got nearly 40k on a 58 plate, and i tow a caravan, i presume causes more stress
and so far, touches wood desk with both hands and feet !!
all ok at the moment
steve
| posted on 15/9/11 at 07:55 PM |
Generally they don't give as much trouble on petrol engines also after about 2002 on Ford Diesels they seem to have improved the spec, usaully
starter fails first to those in the know a the get rid quick warning.
| posted on 15/9/11 at 08:02 PM |
Also listen for a knocking at idle . I've had a couple that have somehow rotated the center section so that the holes that the flywheel bolts go
through to secure the outer section don't line up with the bolts meaning the flywheel has to be cut using a cutting disc to remove the bolts.
The concentric slave cylinder needs changing at the same time meaning even more expense
theduck
| posted on 15/9/11 at 08:11 PM |
When it goes depends much on how the cars been driven, a car driven with mechanical sympathy the dmf will last a long time, however a car driven badly
will have the dmf fail much sooner.
snapper
| posted on 15/9/11 at 09:59 PM |
80k and have had the starter off twice for a bearing rebuild and a general clearing.
Replacement is from £550 but the cheapest I have found fitted is £750.
Clutch still works with little problem so am banking the money for the inevitably.
Biggest pain is getting the starter off not a lot of room.
Oh it's on a 53 plate 130bhp TDCI
I eat to survive
I drink to forget
| posted on 16/9/11 at 08:14 PM |
Loads of room if you take the fan housing off.
Norfolkluegojnr
| posted on 16/9/11 at 10:05 PM |
Thanks guys,
Off to look at a couple tomorrow, will report back!
