Author: Subject: Corroded wheel repair
posted on 22/12/11 at 09:30 PM Reply With Quote
My brother has a tyre that keeps going flat due to corrosion on the lip. Problem being its a 21" AC schnitzer thats out of production, and is thousands to replace all 4. Can anyone confirm that this can be repaired by one of the alloy wheel refurb places? If so, any recommendations in leeds?
Cheers!
austin man
posted on 22/12/11 at 09:59 PM Reply With Quote
could possibly have it cleaned up and welded just depends on how bas the corrosion is
mark chandler
posted on 22/12/11 at 10:02 PM Reply With Quote
They usually wire brush off the bad paint, then apply a rubbery solution around the edge of the wheel where the bead sits and stick the tyre back on.
Either that or refinish the inside of the wheel, so rub down and paint
Simon
posted on 22/12/11 at 10:06 PM Reply With Quote
Stick a tube in it
Simon
mookaloid
posted on 22/12/11 at 10:24 PM Reply With Quote
Had a couple of wheels straightened near york http://www.ianjemison.co.uk/ a few weeks ago - he seemed to know what he was doing and some interesting cars were there to look at too.
posted on 22/12/11 at 10:36 PM Reply With Quote
cheers all! I'll call that place tommorow mark, thanks!
He's literally on about a new set costing £3500
posted on 22/12/11 at 10:59 PM Reply With Quote
Simplest Knock it off the rim wire or nylon brush with angle grinder, re-lacquer then fit tyre with loads and loads of tyre fitters soap.
Litemoth
posted on 23/12/11 at 10:06 AM Reply With Quote
As Mark says above, the solution is a wire brushing of the seat and an application of bead sealer. its made for this application. Tyre soap is all that is used normally
posted on 23/12/11 at 10:17 AM Reply With Quote
Rub the inside of the rim down and mastic it then put the tyre back on and inflate it before the mastic sets, worked on my scooter.
