bigfoot4616
| posted on 28/12/11 at 08:10 PM |
R1 5VY wiring
finally got back onto the wiring today and have a connector i'm not sure what its for. can't find it in the wiring diagrams
the one on the right
its a 6 pin connector with
red/white Ign live
red/green backup fuse
yellow/blue ecu and dash/headlight loom con.
light green dash/headlight loom con.
black earth
black unknown 2 pin plug on left( the other black from that plug connects to the backup fuse via the red/green above)
i know the red/black and red/white stop switch wires need shorting and powering from the ignition switch. should that be done via the FIA cut off
switch?
thanks
A1
| posted on 28/12/11 at 08:53 PM |
just off the top of my head, the one on the left is the oil level sensor.the other one I cant remember. might be coils/injectors...
If youre still stuck i can look tomorrow and let you know.
bigfoot4616
| posted on 28/12/11 at 10:03 PM |
not to bothered about the left one but don't think its the oil level. already got that accounted for.
definatly not coils or injectors, they are all wired up
