andyharding
| posted on 24/8/04 at 07:46 PM |
Zetec Engine Mounts
Just finished my Zetec engine mounts and thought I'd share a few pics...
Offside mount:
  O/S Engine Mount
Nearside mount:
  N/S Engine Mount
Type 9 gearbox mount:
  Type 9 Mount
I love speed :-P
| posted on 24/8/04 at 08:16 PM |
looking very nice andy
Don't Steal
The Government doesn’t like the competition
dave1888
| posted on 24/8/04 at 08:31 PM |
How far does your sump hang below the chassis rail with them mounts
andyharding
| posted on 24/8/04 at 09:12 PM |
6cm with a standard Escort sump.
It will be shortened.
andyharding
| posted on 25/8/04 at 07:45 AM |
Series 2 Land Rover petrol.
Micael
| posted on 25/8/04 at 01:53 PM |
I might copy your gearbox mount. It look very nice
andyharding
| posted on 25/8/04 at 02:17 PM |
Go ahead.
I suspected a few people might be interested in it because the standard Sierra one is pretty crap. It is very soft and reduces ground clearence in the
worst place possible.
Mine only cost £2.64 to make which I would imagine is a hell of a lot cheaper than a new Sierra mount.
garage19
| posted on 25/8/04 at 03:12 PM |
If you get the square V8 landrover mounts they are a bit more heavy duty my local Landy place stocks them for a laughable 2.60 each!
Mix
| posted on 25/8/04 at 04:47 PM |
How big is your bonnet bulge going to be ??
Mick
andyharding
| posted on 25/8/04 at 06:39 PM |
I won't need one.
I'll be using body work from GTS. Tthe front of their bonnet is 8.5" high, with the engine where it is the top of the cam pulleys is
8" high.
Hopefully
mackie
| posted on 26/8/04 at 08:04 AM |
I'll bear those rubbers in mind because I'm going to need to make up a mount for our Rover LT77 gearbox.
The standard one has rubber blocks that screw into 2 angled bits on the rear of the gearbox.
Like this:
I'm wondering if that arrangement is needed (is it there because of the torque?) or if I can just bolt directly into the bottom (there are
already threaded holes) using something like a landrover engine mount rubber. That way would certainly be simpler to fabricate.
andyharding
| posted on 26/8/04 at 08:48 AM |
I'm no engineer but...
I think most of the torque will be taken up by the engine mounts on the Zetec engine and the Type 9 mount is just to stop the gearbox moving round
under acceleration and cornering etc.
If you have engine mounts that will stop your engine turning under the torque I don't think there will be a need for a gearbox mount thats takes
up torque as well.
mackie
| posted on 26/8/04 at 09:07 AM |
That's what I would have thought too. Would make it a simpler job certainly!
Better picture of the rover SD1 mount:
[Edited on 26/8/04 by mackie]
| posted on 26/8/04 at 12:58 PM |
Very neat engine/gearbox mounts Andy.
Only snag I can see is it's going to be a real water trap in it's present state. Drilling a reasonable size drain hole near the bottom of
the square tubing and/or fitting some kind of cap would fix this. Alternatively make the nut captive and then just weld a plate over the top.
[Edited on 26/8/04 by MikeRJ]
andyharding
| posted on 26/8/04 at 02:55 PM |
I had thought about a drain hole but decided I'll only do it if it's needed. I'm not planning to drive in the wet!
You would'nt be able to tighten the mount properly if it was a captive nut plus you'd need to use a spring washer or something to stop it
vibrating undone.
Micael
| posted on 6/9/04 at 08:51 AM |
Hmm, I dont have these two bolt holes on my Type9. Is thre different kinds of Type9:ers??
Micael Moose Åman
Petrolhead and all around nice guy
"Don't leave the duck there. It's totally irresponsible. Put it on the swing, it'll have much more fun." //Sleep Talkin Man Dec 23
2009
stevebubs
| posted on 12/8/05 at 05:48 PM |
could be from a grannie...
