Koso RX2 Digital Dash - Ideal for BEC
Still all new in the box
Retail at £250
Will do for £200 delivered
•Easy-to-read gauge with dial-type tachometer and digital display
•Back-lighting can be changed to seven different colors to match any preference
•Back-lit dial with lighted needle shows tachometer with 15,000 rpm range
•Back-lit digital display shows speed (0-223 mph/0-360 kph), odometer, two trip meters, water temperature, oil temperature, clock and fuel level
(10-bar display)
•Adjustable speed warning, over-rpm shift light, over temperature warning and insufficient fuel warning
•Keeps record of top speed, max rpm and top temperature
•Also features target speed timer, target distance timer and top speed timer (speed, distance, rpm and timer)
•Indicator lights show neutral, high beam, oil pressure, rpm shift light, speed warning, turn signals and check engine
•Gauge measures 105mm H x 180.15mm W x 49mm D
•Includes gauge bracket, water temperature and speed sensor with bracket and magnet
[Edited on 11/8/12 by Ryan.G]
