kingster996
| posted on 2/12/14 at 11:39 AM |
FS: NEW Golf fit Rear Calipers - SOLD***
These are the Rally Design Hydra-Mech calipers - but are almost identical to Mk4 Golf ones used on many kits.
I bought these for my Westfield build, but due to the location of the hydraulic inlet, they just didn't fit - due to my kit being a Sierra SDV
with 'fat' uprights.
They might fit other kits as the Westie uses a cast alloy rear upright that is quite bulky - but just be aware of where the inlet is - see pics.
They have never been used, just tried to fit them, so are as new apart from a couple of scratches on the springs.
I also have a set of hoses to fit and the 12mm banjos. The hoses have compression fittings but I preferred to get some made up by Hel with swaged
ends, so these are now spare and FREE with the calipers.
The calipers are £49 +VAT each from RD but as I have kept the carriers,
I'll take £30 + post for the pair of bare calipers and the hoses - which is less than the cost of the pistons and seals if you need them!
[Edited on 2/12/14 by kingster996]
[Edited on 3/12/14 by kingster996]
I used to be indecisive, but now I'm not so sure
liam.mccaffrey
| posted on 2/12/14 at 11:43 AM |
Offer withdrawn due to a misunderstanding on my part. Apologies.
[Edited on 2/12/14 by liam.mccaffrey]
Build Blog
Build Photo Album
kingster996
| posted on 2/12/14 at 11:45 AM |
Blimey that was quick - first dibs are yours!
kingster996
| posted on 2/12/14 at 12:52 PM |
Still for sale - slight misunderstanding - so, just to clarify, there's no carriers included.
Chris
bart
| posted on 2/12/14 at 01:51 PM |
ive just fitted a pair to westfield uprights what problems did you have ?
BE ALERT > BRITAIN NEEDS LERTS
kingster996
| posted on 2/12/14 at 01:57 PM |
Probably down to my setup - 240 disc on a sierra SDV rear upright:
Replaced with some others - they were tight, but fit:
Bart - looked at your pics - you have bigger carriers and smaller upright (ie std Westfield, as opposed to my SIerra SDV Westfield) - so these will
fit most other setups I guess!
JC
| posted on 2/12/14 at 05:39 PM |
If this is 2 calipers, just without the carriers, then could I have second (first?) dibs please?
kingster996
| posted on 2/12/14 at 08:11 PM |
Yes, U2U replied to James.
