cliftyhanger
| posted on 1/11/16 at 12:08 PM |
Buying gaskets/seals/bearings for st170
Having a bit of a nightmare.
Having stripped my st170 engine, I assumed it would be easy to find all the gaskets I wanted.
I don't want a complete set of top and bottom gaskets, besides it is hard to find a top set as the cam box gasket is different.
Bottom end I don't need the sump gasket as I have a CVH sump.
But it seems it is very tricky finding all the gaskets and seals (especially the cam seal fo the VVT) at a decent price. Even a water pump O ring
seems to be £15!!
So any pointers on where to get stuff. Burton have some bits, but anywhere else worth a try.
Oh, and what thickness head gasket is standard? anybody know? (mine measures at 1mm but that is uncompressed)
It is easier to get stuff for a 50 year old Triumph! (maybe they need more rebuilds....)
Clive
procomp
| posted on 1/11/16 at 12:28 PM |
Hi.
We are running a ST170 race motor. And yes it's a pain to get anything. The only parts i have been able to get aftermarket is a rocker cover
gasket. ( PAYRC 7383 ) everything else is ford dealer. For upgrade on spark plugs try NGK LTR7X-11.
Cheers Matt
chris
| posted on 1/11/16 at 12:59 PM |
My exhaust cam seal was leaking so took it out and compared it to standard zetec one it was the same so fitted that didn't look at inlet cam
[Edited on 1/11/16 by chris]
cliftyhanger
| posted on 2/11/16 at 05:46 AM |
Hmm,that isn't great. Especially as so much stuff is shared with the "normal" blacktop.
Guess I will end up with a few spare gaskets.....and a smaller bank balance
