redeye
| posted on 25/3/05 at 01:06 PM |
2.1 pinto
hi all
im currently looking into starting a projext engine for when my car is finished
im planning on getting a 2.0 pinto and having it rebored to a 2.1
what im wondering is will the twin 40 webers work ok with this size engine or would i need to get hold of twin 45's?
cheers
patrick
NS Dev
| posted on 25/3/05 at 01:12 PM |
40's will "work" but it depends on how much power you will expect to make. If you are spending money on building the 2.1 then
presumably it won't be standard, in which case you will probably need 45's. As a stab in the dark, I would say much over 140hp (obviously
on a 4 cyl engine!!) will require 45's.
[Edited on 25/3/05 by NS Dev]
Northy
| posted on 25/3/05 at 01:15 PM |
Why not fit bike carbs or bike throttle bodies?
Graham
redeye
| posted on 25/3/05 at 01:19 PM |
not sure really
only jus started thinking about it
would be upgrading the cam for sure tho
