Author: Subject: IRS wishbone bushes
mark chandler
posted on 23/9/05 at 12:24 PM Reply With Quote
IRS wishbone bushes
I,m just about to start knocking up my chassis et al, For the front wishbones the road end is always tied solidly, ie track rod ends ball joints etc. Looking at various pictures it appears that most cars have bushes at both ends of the wishbones on the rear.
So my question is simple, is it worth going to the effort of rose jointing the road end of the lower wishbone on the rear or just use bushes. I am going to copy the front, a Y shaped wishbone with track rod ends at the top so I can adjust camber (most cars I have had always had solid bushes or needle bearings on the outside).
The cars going to be blade engined for track day fun & road.
gustavo_brum
Junior Builder
Posts 17
Registered 31/7/05
Member Is Offline
Photo Archive Go!
Building: modified locost, chevette running gear,VW engine
posted on 23/9/05 at 12:32 PM Reply With Quote
In theory, Mark, rose joints offer more control since the arms pivot around fixed points. Bushes are designed to absorb high frequency vibration that can´t be dealt with by the spring and dampers, so it´s basically aimed at ride comfort. It is all about compromise, as is everything in a car. But since you already use rose joints up front...
mark chandler
posted on 23/9/05 at 12:46 PM Reply With Quote
I,m not using rose joints up front as I will use bushes on the chassis end, the standard design utilises solid style mountings at the road end.
I,m just wondering what the effect of rubber bushes at both ends have, in theory twice the flex but will I notice it ?
gustavo_brum
Junior Builder
Posts 17
Registered 31/7/05
Member Is Offline
Photo Archive Go!
posted on 23/9/05 at 02:29 PM Reply With Quote
you might notice it only if racing hard, on the other end, if you use rose joints all around you will certainly feel every small bump on the road... In my case, since I am building my own version of the locost in Brazil (chevette donor, no sierras were ever sold here), and I want it to be a daily driver, I´m going for rubber bushes all around. Again, it´s all a matter of compromise.
Mix
posted on 24/9/05 at 09:59 AM Reply With Quote
I've gone for rose joints on the inboard end and bushes outboard on my IRS, I wanted to have a degree of adjustability and that seemed a good way of getting it.
Mick
Bob C
posted on 24/9/05 at 06:34 PM Reply With Quote
I've done the same as "mix" and for the same reason.
Bob
907
posted on 24/9/05 at 08:27 PM Reply With Quote
I'm with you two, just the other way round.
Poly bushes inboard, rose joints on the upright.
Paul G
