Author: Subject: complicated steering
derf
posted on 7/11/05 at 03:21 AM Reply With Quote
Nuff said
[Edited on 7/11/05 by derf]
sgraber
posted on 7/11/05 at 03:46 AM Reply With Quote
Yah, that's Micke Fredriksson's steering setup isn't it? His legs go up past the a-arms so it's probably the only way to route it.
Wonder if there is noticeable slop?
Steve Graber
http://www.grabercars.com/
"Quickness through lightness"
NS Dev
posted on 7/11/05 at 10:15 AM Reply With Quote
would have surely been easier to get different uprights so the rack could be mounted in front of the axle line rather than behind it?
DarrenW
posted on 7/11/05 at 12:16 PM Reply With Quote
Surely there must be an alternative rack out there that can be used so you are starting from the right (read wrong!) side.
if the joints are all new and well made then slogger should be controlled. I cant help thinking that the tortuous route could lead to wear over time. Looks a tad complicated for a sports car.
NS Dev
posted on 7/11/05 at 12:43 PM Reply With Quote
........in engineering the simplest solution is invariably the best.......
it certainly does not appear simple!
posted on 7/11/05 at 01:05 PM Reply With Quote
His seat is in the middle and the fuel tank is in front of him. Steering arm position wouldn't make any difference it would still have to bend. He's probably doing what we all do, making the best use of the materials to hand. It's passed Swedish equivalent SVA so it must be alright.
[Edited on 7/11/05 by Peteff]
ch1ll1
posted on 7/11/05 at 09:52 PM Reply With Quote
wish i had thought of that !
davidwag
posted on 8/11/05 at 09:09 PM Reply With Quote
Can't quite make it out.
Do you sit with your legs in front of the axle line?
