Author: Subject: gsxr 750 throttle bodies
APR
posted on 8/11/05 at 10:38 PM Reply With Quote
can i use the gsxr injectors for 2.0 zetec with mild tuning ( cams/gas flow) or will i need to change them, if so anyone know what to?????
stevebubs
posted on 9/11/05 at 01:08 AM Reply With Quote
Should be fine.
However, I changed them for car injectors from a Vectra GSI (Purple Trim on injector).
Was going to use Cossie injectors but they're a little too high a flow rate
Stephen
FlansS14
posted on 9/11/05 at 09:47 AM Reply With Quote
Steve, What engine are you running them on. and which ecu.
Im gonna be running them on a 1.6 se engine. is the tps compatible.
Flan
