Author: Subject: R1 Clocks
welderman
posted on 18/1/06 at 08:45 AM Reply With Quote
R1 Clocks
Any one know when all plugged up why my oil light comes on, temp too high and fan starts up. Before i even turn the engine over.
Oh, also does it when running.
Thank's, Joe
I don't stalk people
Coose
posted on 18/1/06 at 09:02 AM Reply With Quote
Have you got the oil level switch connected? Are you using an R1 temp sender? What year is the motor, and what year clocks are you using?
Spin 'er off Well...
welderman
posted on 18/1/06 at 09:13 AM Reply With Quote
Just had a look, it's not the oil it's the coolant temp warning light that stays on. Im using the original R1 clocks and digi readout is flashing HI.
Thank's, Joe
smart51
posted on 18/1/06 at 09:55 AM Reply With Quote
If the screen says HI then the coolant temperature sensor thinks that the coolant is above 130° IIRC. Do you have the temperature sensor connected? 98 / 99 R1s have a separate temperature sensor and thermostat switch later ones have a single combined sensor.
welderman
posted on 18/1/06 at 12:03 PM Reply With Quote
Sensor conected goes hi and fan on, unplug it and is low and no fan on. Think it's the sensor.
Thank's, Joe
Coose
posted on 18/1/06 at 12:26 PM Reply With Quote
I take it that you're motor and clocks are 2000/01, and using the single temp sensor where the clocks switch on the fan?
It does sound like you have a dead short in your temp sensor. If you have a manual to hand it should give the resistance reading across the sensor at various temperatures. Unfortunately mine is at home so I won't be able to look before tonight.....
Coose
posted on 18/1/06 at 12:27 PM Reply With Quote
p.s. Your avatar is soooooooooo transfixing!
welderman
posted on 18/1/06 at 01:27 PM Reply With Quote
Coose
Thanks for the reply, got copy of manual off net, it's buggered.
Got to get me another and see if all works.
thanks
Keep on looking at Atvar makes me smile
[Edited on 18/1/06 by welderman]
Thank's, Joe
Coose
posted on 18/1/06 at 02:54 PM Reply With Quote
No worries, any time!
I just can't help staring at it - it's hypnotic! I might have to 'borrow' it to brighten up my day!
p.s. 'Er indoors likes the idea of an R1 Mini to go with her '66 mk1......
Hmmmm........
welderman
posted on 18/1/06 at 04:22 PM Reply With Quote
Go for it mate, if she want's she gets. Am i right in saying that.
Thank's, Joe
alfasudsprint
posted on 18/1/06 at 08:06 PM Reply With Quote
Welderman,
where can I get a copy of the manual????
Coose
posted on 18/1/06 at 09:43 PM Reply With Quote
You can get all parts books and manuals on cd from www.fiche-man.com.
He will send you a top quality cd for a small fee. He covers most modern bikes too!
welderman
posted on 18/1/06 at 11:49 PM Reply With Quote
look here, you have to regiser but.
http://yzf-r1forum.net/manuals/index.html
Thank's, Joe
welderman
posted on 19/1/06 at 07:59 AM Reply With Quote
Thanks Chris, but it deffo is the Temp sender. But also anychance you can make the diagram bigger just cant quite see the writing mate.
Thank's, Joe
