marcotuinenburg
| posted on 29/5/06 at 06:54 PM |
what battery is best ?
Im trying to find out what's the best battery for my BEC.
I'm building a MK Indy with SC33 E fireblade engine from 1999.
The Haynes says 12 Volt, 8 Ah but do i need more amps because of the extra lighting for the car ?
And do i need heavier fuses ?
Thanks,
Marco
[Edited on 29/5/06 by marcotuinenburg]
peterriley2
| posted on 29/5/06 at 06:57 PM |
most people just use the bike battery, its lightweight and can happily power all the lights etc.
joel
Joel
If you dont respect yourself, dont expect respect from anyone else
Live your dreams, dont dream your life
Women only want you for one thing- everything!
chockymonster
| posted on 29/5/06 at 07:53 PM |
I've gone for an Odyssey PC535 battery, it's light but has a higher amperage.
RazMan
| posted on 29/5/06 at 08:31 PM |
The Odyssey will just give you more cranking power (which is nice) A bike engine only requires a bike battery - it's the alternator which
might not be able to keep up with your electrical equipment.
Raz
Jon Ison
| posted on 29/5/06 at 08:41 PM |
never had a prob just using bike battery, nice small light n compact.
marcotuinenburg
| posted on 29/5/06 at 08:45 PM |
Aha, thanks for your advice.
I will get a new bikebattery this week.
ChrisGamlin
| posted on 29/5/06 at 09:30 PM |
I'd suggest getting a slightly bigger bike battery than 8Ah though, such as a 12Ah YTX12. I had a 9Ah one originally with my blade and although
it was generally fine, it did occasionally need the jump leads across it if the car hadnt been driven for a month or two, so its nice to have that
extra capacity especially if you're not planning on putting a 24/7 trickle charger on it (Optimate etc) to keep it totally fresh all the
time.
[Edited on 29/5/06 by ChrisGamlin]
RichieC
| posted on 29/5/06 at 10:25 PM |
Yeh Id go for a 10Ah minimum.
Not wanting to contradict Chris, but beware the YTX12 is a 10Ah, the YTX14 is the 12Ah.
Ar5e about face I know and an easy mistake
Rgds
Rich
ChrisGamlin
| posted on 30/5/06 at 05:31 PM |
Ah yep sorry, I had a YTX9 before but that was probably 8Ah?
