Deckman001
| posted on 3/9/06 at 05:55 PM |
Shox re-bushing ????
Hi all, has anyone here had to replace their shox bushes ? I've a set of avo's that have a 7/16th hole (11.03)on them, but my bracket is
approx 10mm and I can't get a drill in to re-drill it bigger, so I was thinking of changing the metalastic bush to a smaller bored one of 10mm,
any thoughts ??
Jason
| posted on 3/9/06 at 05:58 PM |
i need to do this too, as my bushes have sagged drastically. Was thinking of removing the full lot and either replacing or maybe get a spherical
bearing to use.
Deckman001
| posted on 3/9/06 at 06:00 PM |
Would it be easy to convert to rod end ?? it's only the top mount I have a problem with !
Jason
ned
| posted on 3/9/06 at 06:24 PM |
it might be easier to find someone to turn some tight fit sleeves to set the holesize down on a lathe?
beware, I've got yellow skin
Deckman001
| posted on 3/9/06 at 09:57 PM |
I did consider that ned, but the sleeve would only be .5mm thick, not sure if it would be poss ??
Jason
Deckman001
| posted on 6/9/06 at 03:50 PM |
No one else then had to do this then ?, not even to replace worn bushes ?????
Jason
ned
| posted on 6/9/06 at 04:26 PM |
maybe try dave at dampertech, he's usually helpful when I've spoken to him at shows..
Ned.
