givemethebighammer
| posted on 10/12/06 at 01:22 PM |
Oil cooler pipe / fittings size
I'm just about to fit an oil cooler (yes I need it, I fitted a oil temp gauge and it reads 100 - 110 degrees on very cold days) to my 2.0L
zetec. The question is what sized fittings to use. The recommendation for engine sizes up to 2 litres is 1/2 BSP, over 2 litres 5/8 BSP. Which leaves
me right in the middle.
What has anyone else done?
thanks
daviep
| posted on 10/12/06 at 02:45 PM |
IMHO I would have thought 1/2" would have be adequate. Plus the fittings and hose are obviously smaller making it easier to make a tidy job of
the installation.
rjs
| posted on 10/12/06 at 03:37 PM |
ive used 1/2 BSP on mine & it is fine . ive been told zetecs always run on the hot side , mine sure seems to .
bimbleuk
| posted on 10/12/06 at 06:17 PM |
1/2" seems quite common. As used on my cooler and Accusump ordered from RAW Engineering. Admittedly they usually fit 1600cc engines in the
Striker but there are Zetecs out there too.
givemethebighammer
| posted on 10/12/06 at 08:25 PM |
thanks people I hoped the smaller fittings would be OK because as was mentioned they'll be easier to fit neatly.
| posted on 11/12/06 at 10:47 AM |
thanks
we're talking oil temp not water
The numbers you list are fine; what are the temperatures on a hot day? Depending on what source ytou read, once you are over 160 then you start to
worry.
ned
| posted on 11/12/06 at 10:53 AM |
use 1/2", I fitted 5/8 on my xe for remote filter head and it was far more expensive than 1/2" and I really don'y think it makes
much difference unless you're going mad with the engine. 5/8 will give fractionally more capacity in the oil system but 1/2 will probably flow
better.
imho
Ned.
beware, I've got yellow skin
chockymonster
| posted on 11/12/06 at 12:26 PM |
Is that all?
My WRX without an oil cooler on a trackday in cold weather was touching 130-140, on a hot day 140 was average.
My old FTO would nudge 130 on a cool day. I'd wait and see what it does on a hot day.
NS Dev
| posted on 11/12/06 at 12:49 PM |
Those sort of temps will totally kill the oil, hope you changed it soon after, as the viscosity improvers will be knackered.
Back to the topic - are you sure you're gauge is calibrated right and in degrees C?
If so I'm shocked!
My Vauxhall, with no oil cooler, just a winged alloy sump, never got near those sort of temps, and thats more powerful?!?
Even on long, high revving motorway trips it would never kick in the thermostat for the cooler. (hence why I took it off! )
