d8mok
| posted on 3/2/07 at 09:55 AM |
camber and castor
i've just finished putting my front end together after its overhaul.
I've had all the arms powder coated, new suspension and new wilwood brakes.
I'm wondering how i go about setting up my camber and castor and suspension? who can do it local or near to chesterfield? Or any body on here
fancy havin a look for me? I'll get u a pint in.
The car is a stuart taylor locoblade.
Many thanks
| posted on 3/2/07 at 11:09 AM |
you can do it rough with a block of wood and a spirit level, but if you want it doing really well, it might be best to take it somewhere and get it
corner weighted at the same time. MNR can do this i believe, but im sure there are others
| posted on 3/2/07 at 11:41 AM |
IIRC castor is fixed on the locoblade (or it was when I built one!!)
Camber and toe-in need a few bits of kit. Nothing too difficult- the main stumbling block for most is the need for a dead flat and horizontal surface
to do the work on....
d8mok
| posted on 3/2/07 at 01:05 PM |
block of wood and sprit level? how do i do this??
And what does IIRC mean?
[Edited on 3/2/07 by d8mok]
907
| posted on 3/2/07 at 03:22 PM |
Or large square (roofing square)
Saves the need for a level surface. A flat surface will do.
At least it gets both sides the same, assuming that's what you want.
Hold it one edge on the ground against the wheel, touching the bottom, and measure the gap at the top.
Paul G
IIRC = If I recall
| posted on 3/2/07 at 04:07 PM |
flat surface, block of wood cut to sit on alloy rim (not tyre as this will deform at the bottom), use spirit level to check vertical angle. This is
the camber sorted. For toe in, i clamp a long length of tubing horizontally to each wheel, extending a few feet (or more) in both directions, and
measure the seperation front and back to work out if they are parallel. Obviously make sure the wheel and rack are centred correctly before adjusting
owt.
Castor is a little harder, im sure you will work something out Myself, id do something with the hubs off and a short length of square tubing bolted
in instead, and make sure its correct before starting on the rest.
