goodguydrew
| posted on 5/4/07 at 06:18 PM |
Suspension bushes too hard?
I bought some lolocost suspension bushes. I have read that they are perhaps too hard.
Is this going to cause me any problems?
[Edited on 5/4/07 by goodguydrew]
designer
| posted on 5/4/07 at 07:00 PM |
For road use metalastic bushes are best
big_wasa
| posted on 5/4/07 at 07:01 PM |
Can you tell me how wide the crush tube is please ?
| posted on 5/4/07 at 07:39 PM |
It might do on the rear where there is a slight twist but the front should not be a problem.
907
| posted on 5/4/07 at 08:36 PM |
Hi
I bought two sets from Lolocost (for front & rear IRS) and the ride is OK.
The problem I did have was that the tubes are cut on a "random" saw.
Everything is half a mil short, half a mil big, or a mil out of square.
The poly bushes are not much better. I/D & O/D are OK but the length of the shoulder varies.
I started off trying to match sets, but ended up facing all the components in the lathe to at least end up with a consistent dimension to make the
chassis brackets to.
Time will tell as far as durability is concerned.
Paul G
