davrus
| posted on 8/4/07 at 05:02 PM |
Front cycle wings
A couple of questions really.
1 Where about have you monted your cycle wing brackets to.
2 How have you fastnened you wings to the brackets.
again pics would be great.
Many thanks for you help
Dave
Check out my website http://www.thedave.co.uk/
Feel free to sign my guest book in the links page.
| posted on 8/4/07 at 10:04 PM |
Bracket attached to the 3 threaded holes in the back of the upright....
Wings to bracket secured by two bolts drilled through the GRP and through the bracket... Some people bond them but I prefer the bolted approach....
Then again, the main problem I have is that the spacer tubes (to create the distance between the upright and the bracket) is that the spacer is made
out of ali and it gets crushed by vibrations when driving- I'm replacing them with mild steel tubes....
ReMan
| posted on 8/4/07 at 11:48 PM |
1. The uprights, but used MAC#1 brackets.
2. PU adhesive, nothing else, so far so good!!
Mr Whippy
| posted on 9/4/07 at 07:22 AM |
Don’t use flat bar to do the vertical parts of the frame instead of the normal tube as I tried this and it simply is too wobbly.
cossiebri
| posted on 9/4/07 at 09:09 AM |
I got my cycle wing brackets from locostparts.net. Very well made, sturdy & look good  drilled and bolted the wings with stainless caphead
allen bolts,I only done this late last night, i'll post a pic on later
If it doesn't fit MODIFY it!!
Cheers BriF
