Nosbod
| posted on 2/12/07 at 06:52 PM |
R1 Clocks.
Does anyone know if clocks from a 4XV will work ok with a 5JJ engine?
Chris.
Coose
| posted on 2/12/07 at 07:39 PM |
No, they won't if you want to just plug in and go.
Spin 'er off Well...
RickRick
| posted on 3/12/07 at 11:13 AM |
does anyone know if i can change the clocks on a 05 r1, there's not part of the immobalise or anything silly like that are they?
Davey D
| posted on 3/12/07 at 12:35 PM |
yes i believe you can swap the clocks over. the imobiliser is in the back of the key barrel which doesnt connect directly to the clocks, it connects
to the part of the loom that goes to the ECU
Nosbod
| posted on 3/12/07 at 09:00 PM |
Thanks for the confirmation Coose, i'll keep looking then :-)
TimC
| posted on 3/12/07 at 09:28 PM |
Ecu is different!
Coose
| posted on 4/12/07 at 02:31 PM |
No worries. As TimC says, the ECU is different as is the temp sender/fan control.
A set will turn up if you bide your time. In fact, there is a set
here, though not cheap. Saying that, they are the going rate as they generally get damaged in a crash and they're a lot cheaper
than most aftermarket clocks!
Actually, have a look
here. These could
be a bargain, but make sure that they're the ones in the photo as the listing is incorrect if they are!
[Edited on 4/12/07 by Coose]
