Gergely
| posted on 17/1/08 at 03:21 PM |
Ford RS 13x6" wheels fit question
Does anyone know if the 13x6" Ford RS wheels - the 4 spoke type old one - would fit an MNR with Sierra rear and Cortina or (if I will be able to
afford) Racelada front ends? Or should I rather go 14" to be sure?
Also, does anyone know the weight of these wheels?
I am planning to go cheap with the parts that I can upgrade later if needed, so looking at second-hand parts for the (hopefully not so distant)
build.
Thanks!
Gergely
gingerprince
| posted on 17/1/08 at 03:46 PM |
can't help on the fitment, but whatever you do don't go for 14's. you only tend to get a good choice of performance tyres on odd
numbered sizes, so 13", 15" etc etc...you'll be seriously limited on 14" wheels.
Guinness
| posted on 17/1/08 at 05:12 PM |
So how come I got a set of Toyo R888's for my 14" donor alloys, off the shelf in Middlesbrough?
Mike
StevieB
| posted on 17/1/08 at 05:20 PM |
I'm doing the same thing - keep it cheap and upgrade later.
I've ust picked up my steel wheels that I've had blasted and powder coated, and will be fitting R888's.
I'd budgeted £500 for wheels and tyres, this way I'll save a bit and have a far better set of tyres too.
For tyres have a look at camskill.co.uk
Avoneer
| posted on 17/1/08 at 05:38 PM |
I've got one wheel in my garage so I'll weigh it for you later - they are light though.
They'll definately fit Sierra rear drums, but I don't think they fit Sierra rear discs.
Pat...
Avoneer
| posted on 18/1/08 at 07:42 AM |
4kg using crappy bathroom scales.
Pat...
Gergely
| posted on 18/1/08 at 08:33 AM |
Thanks guys!
If I stick to Toyo R888's I don't think availability for 14" will be a problem either, but I agree other performance tyre choices
would be limited, good point.
4 kg seems fine to me...
I am planning to use discs, so it seems RS's are not the right choice for me..
procomp
| posted on 18/1/08 at 08:14 PM |
Hi the ford RS wheels weigh 6kg. The compomotive Lightweight CXR's weigh 4.5kg. Just been weighing all these today for a customer.
Cheers Matt
Avoneer
| posted on 18/1/08 at 10:51 PM |
My 6x13 are definately 4kg!
They are genuine RS2000 and not Capri Laser.
Not sure if it makes any difference.
Pat...
