| posted on 29/1/08 at 12:25 PM |
securing bonnet latches
What can you suggest I use to prevent these catches from coming undone?
At the moment I am pushing in a hard plastic tube into the hole but there is possibility, albeit small, of it falling out so am thinking of an R clip
type thing.
  catch
Guinness
| posted on 29/1/08 at 12:37 PM |
Aren't those the ones where you are supposed to lock them with tiny padlocks?
Mike
Mr Whippy
| posted on 29/1/08 at 12:47 PM |
yip try suitcase ones or lynch pins as used on diggers etc.
linky -
http://www.wilsonmfgco.com/fasteners/lynchpins.htm
[Edited on 29/1/08 by Mr Whippy]
ditchlewis
| posted on 29/1/08 at 01:05 PM |
A pin with an R clip through it
alternativly a nut and bolt really quick release
ditch
NS Dev
| posted on 29/1/08 at 01:10 PM |
post SVA I have now fitted bonnet springs like they use on rally car boot lids, the caterham c400 racer has them at the front edge of the bonnet.
Mine has dzus fasteners at each corner which are great for sva (flush fitting) but at 100+mph I get worried as the front of the bonnet starts to get
air under it and bulge a bit
The springs at the front corners give some peace of mind!
caber
| posted on 29/1/08 at 02:11 PM |
What's wrong with the traditional strip of gaffer tape?
Caber
| posted on 29/1/08 at 02:22 PM |
i don;t have any gaffer tape and knowing my luck, it will take the paint of eacjh time it is removed.
I did think about bolt but it would need a nyloc to stop the bolt from undoing but that is not good as I need to be able to do it up by hand, and my
tiny fingers are not strong enough to do up nylocks.
so far the lynch pin seems the best solution - need to measure up the hole and find one that fits.
Actaully what I had in mind was a spring loaded pin with a rotating toggle - hard to explain but if you have one of those usniversal circlip pliers,
then use one.
worX
| posted on 29/1/08 at 03:27 PM |
If you wanted to do it the locost way (or perhaps even free) you could easily just use a Key Ring.
It would prevent it lifting up, but you could remove it in two seconds with your hands. You can get hardier ones if you think it might fail.
Personally, I'd just get some more catches that did the job properly.
HTH
