Colnago_Man
| posted on 1/2/08 at 12:11 PM |
Rubber pipe in tunnel?
While test firing my engine I used some regulation rubber fuel hose. I've now decided to fit this into the transmission tunnel, knowing how
difficult
it can be to p-clip rubber hose without it drooping I though about fitting some lengths of L shaped ally the lenght of the tunnel and fitting the
fuel pipe onto the horizontal surface (may be with p-clips and a self tapper).
I may also do this for the electric wiring on the opposite side of the tunnel.
Also this may provide some extra protection for the fuel pipe in event of a diff/prop shaft failure.
I guess the question is would it be acceptable for SVA?
Diagram attached :
[img][/img]
nib1980
| posted on 1/2/08 at 12:22 PM |
why not ust run a copper pipe through the tunnel like the brake pipes?
Mr Whippy
| posted on 1/2/08 at 12:32 PM |
quite right
| posted on 1/2/08 at 12:33 PM |
Your layout looks good - but I'd also recommend metal tube through the tunnel, as you'll only have to replace the rubber when it
eventually perishes (mine took only 3 years to go). In my case it was a total PITA to change, as trying to get around the propshaft and gearbox was
extremely difficult.
Bluemoon
| posted on 1/2/08 at 12:41 PM |
Yep hard line I'm afraid, whilst SVA man might be o.k. with you set up the rubber will perish and need changing after a few years, and
that's going to be more difficult latter on.
You could always use a ridged plastic pipe (edit: pipe by definition is ridged, hose is a flexible pipe...) designed for fuel this would be easer to
fit than the copper pipe..
Dan
[Edited on 1/2/08 by Bluemoon]
| posted on 1/2/08 at 01:33 PM |
another vote for hard line. go on, it makes snese in the long rong - pity mine was not built like that, at some point I am goona have to replace it
and it ain't gonna be easy.
RazMan
| posted on 1/2/08 at 01:34 PM |
Personally I doubt if the alloy angle would offer much resistance to a broken propshaft flailing around - but then nothing will. Plus you are adding
extra weight too so I would do as suggested and fit a rigid pipe (kunifer or copper) which will take up less space and last the life of the car.
Raz
RichardK
| posted on 1/2/08 at 07:08 PM |
Similar to how I did mine...
Single brake line down and feed and return fuel (just in case I upgrade to a zetec)
Electrics down the other side in convoluted tubing p clipped to the side.
Rich
Gallery updated 11/01/2011
matt_claydon
| posted on 2/2/08 at 09:48 AM |
Yeah, use copper (a roll of 8mm microbore central heating pipe from B&Q for a tenner works perfectly). It makes sense to put a return in now even
if you're going to run carbs as you may want to upgrade to injection in the future. (Wish I had!)
Colnago_Man
| posted on 3/2/08 at 04:57 PM |
Thanks guys, the fact that the rubber might perish never crossed my mind. Copper it is, and yes I'am running carbs but its a great idea about
fitting a return line as I may indeed upgrade the engine in the future...
