Author: Subject: Painting Alu
madrallysport
posted on 28/2/08 at 06:21 PM Reply With Quote
Painting Alu
I'm looking to paint some aluminum, do you go about this the same way as painting an ordinary car panel, or do you need to use a different / special primer. Just after some advice so i can get supplies ready for saturday.
[Edited on 28/2/08 by madrallysport]
UNDERSTEER is when you hit the wall with the front of the car.
OVERSTEER is when you hit the wall with the rear of the car.
HORSEPOWER is how fast you hit the wall.
TORQUE is how far you take the wall with you.
martin1973
posted on 28/2/08 at 06:26 PM Reply With Quote
you will be needing acid etch primer for that or the paint won't stick and will fall of in days
martin
r1_pete
posted on 28/2/08 at 06:27 PM Reply With Quote
I always go for a 160 - 200 grit DA sander'd finish, and etch primer, ordinary primer will eventually flake due to the way ally corrodes.
[Edited on 28/2/08 by r1_pete]
foskid
posted on 28/2/08 at 09:39 PM Reply With Quote
before you paint it give it some anti corrosion treatment like alocrom 1200
posted on 28/2/08 at 11:00 PM Reply With Quote
You need to use at least a "special metal primer" from B+Q. It's preferable to use an acid etch primer (available from places like Halford). Be careful when spraying acid etch primer, the wind changed direction when I was spraying and I almost nuked my eyes....
Chippy
posted on 28/2/08 at 11:38 PM Reply With Quote
Agree with all the above, but give the ally a good going over with a fine wet and dry paper before you put the etch primer on, bit like belt AND braces HTH Ray
posted on 29/2/08 at 07:51 AM Reply With Quote
Originally posted by Chippy
Agree with all the above, but give the ally a good going over with a fine wet and dry paper before you put the etch primer on.
why? as soon as the aluminium is exposed to the oxygen in the air, the surface oxidises. just wipe it down with use some degreasing agent.
vinnievector
posted on 29/2/08 at 08:23 AM Reply With Quote
hi
Hi we treat loads of alu at work in the aircraft ind .
IT all depends of wot grade alu you have some alu comes already clad coated but if this has being damaged then you will need to retreat this with alu chromate 1200. Normal alu primer can be applied to undamaged clad coated alu
Iam guessing that this is perhaps low grade alu and if you going to keep the car for some time it may be worth the effort to do the above but for me I would just scotch bright the surface to key it clean off with solvent tac wipe and your ready to etch prime . hope this helps if you require some paint numbers i can get you those and they are a to part mix hardener and paint.
madrallysport
posted on 29/2/08 at 08:30 AM Reply With Quote
Cheers Guys thanks for all the advice, vinnievector, can i have the paint codes please, just to make sure i'm getting the right stuff.
vinnievector
posted on 29/2/08 at 08:33 AM Reply With Quote
hi
in work tonight so will think on and get you the numbers , will be sat morn earliest hope thats ok
