clairetoo
| posted on 9/6/08 at 08:42 PM |
Gearing.....
Now that I can finally thrash my car , I`ve found a bit of a problem - its too fast !
By that I mean the gearing is way too high - it will do 70 in second , nearly a ton in third , and so far I`ve had 120......in fourth and still
pulling like a train
I`ve already bought a 4.1 diff off fleabay to replace the 3.89 thats in there , I'm even wondering about going lower ?
Anybody got a guide to working out theoretical speeds/gearing type calculations ? I`m not too good at that sort of thinking
Its cuz I is blond , innit
Claire xx
Will weld for food......
| posted on 9/6/08 at 08:47 PM |
This is good...
GearCalc
Used by quite a few folk on here, I believe...
mackei23b
By my reconing and what you have said, with the 4.1 fitted you'll top out at 66 in second if that helps?
| posted on 9/6/08 at 08:52 PM |
You sure you're speedos not reading wrong?
clairetoo
| posted on 9/6/08 at 09:05 PM |
Nope - pushbike speedo , checked with a satnav.......
Claire xx
clairetoo
| posted on 9/6/08 at 09:19 PM |
quote: Originally posted by David Jenkins
This is good...
GearCalc
Thanks for the link - that is just what I need !
I`ve had a quick play , and it looks like I need a 4.5 diff.......
That would still give me 130mph at 7000 - sounds about right to me , but where can I get one of those cheap
Claire xx
mediabloke
| posted on 9/6/08 at 09:37 PM |
Elsewhere on the web, someone suggested that you can get a 4.5:1 Subaru diff. I'd guess you'd have to source some custom driveshafts,
unless you got lucky with the Subaru track...
clairetoo
| posted on 9/6/08 at 09:44 PM |
Its a live axle car........so thats not really an option
A quick search of fleabay , and I`ve found a 4.44 already !
Any one need a 4.1 (when it turns up , I've not even got it yet ! )
Claire xx
mediabloke
| posted on 9/6/08 at 10:02 PM |
Sorry - v. good point.
V6, live axle, 120mph in 4th... sounds like sideways fun.
[Edited on 9/6/08 by mediabloke]
Volvorsport
| posted on 9/6/08 at 10:48 PM |
id keep the gearing like that .
1st might endup being all wheelspin !
www.dbsmotorsport.co.uk
getting dirty under a bus
DIY Si
| posted on 9/6/08 at 11:45 PM |
That sounds similar to the gearing I'm planning for my Epona. It should have 63 in 2nd, 91 in 3rd, 124 in 4th, and top out in 5th/6th, depending
upon gearbox, at 152. That's running a 3.62 diff with 15"wheels.
clairetoo
| posted on 10/6/08 at 06:06 PM |
And that would be a problem because...?
Claire xx
