Bedford Autodrome GT Circuit.......any good for 7's??
Rob Bartley - 12/7/13 at 12:07 PM
Got the possibilty of doing Bedford GT circuit on Monday, but not sure if it is just a big, flat, long featureless experience??
What are people's thoughts? The Procomp LA Gold now has a Nissan SR20DET engine literally shoehorned into it, courtesy of my good mate Duncan Grier Power level is guestimated to be around 210-220 bhp.
Got out in the car for the first time in almost 4 and a half years at a Blyton track day on Saturday! Forgotten how much fun it is, couldn't stop grinning and want more. Considering the SR20DET is a big ol'lump, the overall balance of the car is still remarkable and because we ran lowish boost, felt almost like an N/A but with more mid-range.....awesome!
Anyways......is it worth doing the GT circuit?
Cheers in advance, Rob.
jeffw - 12/7/13 at 12:17 PM
Bedford is great fun but, and it is a big but, they are very tight on noise.
Rob Bartley - 12/7/13 at 12:26 PM
Cheers for the heads up Jeff.......the SR20DET can hardly be heard when watching from the sides, so hopefully should be fine.
pekwah1 - 12/7/13 at 12:28 PM
I've done bedford a few times now in different cars (mainly jap turbo wagons).
It's a great circuit for newbies as it's quite hard to crash there, and believe me i tried!
As for in a 7 i couldn't tell you, but there were 7s when i've been on track there, you'll find there's quite a mix.
I would recommend it as a good track, a couple of nice straights for some speed and a good mix of different corners.
Hope this helps!
Rob Bartley - 12/7/13 at 12:41 PM
Cheers pekwah1
mark chandler - 12/7/13 at 12:58 PM
Great fun, you can slam into the bends without danger of hitting anything so flat out everywhere.
Petrol stations a couple of miles away.
Just watch the induction noise if a BEC
stevebubs - 12/7/13 at 04:45 PM
From memory, the GT circuit is a little big...there is a smaller, tighter handling track that is fantastic for sevens...
bi22le - 12/7/13 at 06:50 PM
Im going on 27th and am looling forward to it. I wanted to go some where faster so I can stretch the skrikers legs. Also I want to find the limits of the car and that needs space!!!
froggy - 12/7/13 at 07:10 PM
If its the full gt course then it can be a bit long if you don't have a lot of power. I did it last August on a scorching day and had a great time , plenty of room and nothing hard if you come off
bowood14 - 12/7/13 at 08:09 PM
As said very tight on noise, I passed all the tests but still got pulled in had to spend most of the time at half throttle. Also as said Great track though
rodgling - 12/7/13 at 08:21 PM
Cool, see you there Bi22le. I've finally got my car set up properly with decent tyres all round so looking forward to trying Bedford again - last time my setup was not very good and I blew up an engine with a money shift :-( So should have a better time this time round :-)
I've been there once before, it's a very safe track with loads of run-off. As previously mentioned, they are really tight on noise so bring an exhaust silencer thingy just in case.
