Chassis construction: Alu vs steel skin?
Philippe - 10/1/06 at 11:47 AM
I have been critical (on various forums) of the way the Book Locost chassis and the Lotus chassis are assembled. The riveting of aluminum panels, floor. bulkhead to steel tubes does not make good use of the stiffening property of sheet metal and also potentially limits the life span of the chassis.
In my build I am considering replacing all sheet aluminium panels, floor, bulkheads with light gauge sheet steel.
My plan is to mig-weld the panels to the tubes in a sequential manner so that tube distortion will not take place. Before welding the panels to the chassis I will roll bidirectional stiffening beads to the said panels, floor and bulkheads in order to enhance their rigidity.
My questions are these.
1) Does any one of you who work with CAD files have the total aluminium area of the Book Locost handy... and would you mind telling me what it is so that I could calculate the amount of additional dead weight the above strategy will cause and make a final decision?
2)What do you think of my suggestion to use steel?
Philippe.
_________________
flak monkey - 10/1/06 at 11:58 AM
Loads of people use steel floors instead of ali ones.
When i did some calculations a 2mm ali floor was around 5-6kg lighter than a 1.2mm steel one.
Ali panels weigh only 1/3rd as much as steel ones. So even if you halve the thickness for steel panels an ali one will still be lighter.
I am not sure if its been suggested to you to use strutcural adhesives (3M VHB tape is good stuff) to bond the ali panels to the chassis, along with a few rivets, you will end up with a similar stiffening effect to that of welding in steel panels.
The use of structural rivets to hold the floor and other panels on is well known, and if its good enough for the aerospace industry, it's sure as hell good enough for a Locost. The next best thing to use are closed end rivets.
The other problem is distortion in welding thin sheet steel. Try it, and you will see. However careful you are, you will always get distortion with thin sheet, its an inherent parts of the welding process (i.e. loads of heat!)
In short, for the amount of miles your average locost will do, theres no need to worry about failure of riveted ali panels. (To my knowledge there havent been any)
You can use steel but it will be significantly heavier.
All IMO, but there we go.
Volvorsport - 10/1/06 at 11:58 AM
my chassis uses grp/kevlar to replace the aluminium , no distortion , good strength to weight ratio, and can be done at home . I also made the tunnel completely in kevlar , so ive saved on tube also .
have you looked at an AC chassis ? complete sheet metal with tube subfames .
you still have to skin the outer layers , to make em look nice .
Bluemoon - 10/1/06 at 12:03 PM
I what why does the Ali pannels limit the life if the chassis? If properly constructed it should not (i.e sealed, and carfull choice of rivet to aviod galvanic corrosion). The whole point of a space frame is that it takes the loads via compression and tension in the tubes... The pannels are not load bearing it should not fatigue...
[Edited on 10/1/06 by Bluemoon]
Philippe - 10/1/06 at 12:04 PM
R-Thanks,
I am aware of the riveting techniques in airplane construction and You may be right.
However what I would like before I make a decision is to document the actual weight saving gained by using riveted aluminium.
Philippe.
oliwb - 10/1/06 at 12:05 PM
Wouldn't bother with the steel to be honest it sounds like a bit of over-engineering to me! I'm not saying that you wouldn't notice any difference but function over form and all that - Ali is lighter, and as mentioned I've not heard of any failures yet! I'm going with the if its good enough for everyone else, its good enough for me plan! Obviously my opinion but hey in this world that's all you got right?! Oli.
Philippe - 10/1/06 at 12:08 PM
R-Thanks. On the Book Locost, have you made your own comparative analysis between: alu, GRP, and steel, in terms of weight?
Philippe.
Volvorsport - 10/1/06 at 12:16 PM
yeah , the less resin you use , the lighter it will be , but you have to try and keep with the recomended resin/glass ratio - which is 1:1 for most cloths and weaves .
altho ive not weighed it before and after - ive used 4 -5kgs of mat so about 5 kgs of resin , so about 10 kgs altogether , but i have no central top tubes and no diagaonals in the footwell/tub area .
Also those 10 kg comprise the full enclosed tub - so the panel on the top of the footwell is closed off , and of course the trans tunnel is done aswell .
cossey - 10/1/06 at 12:30 PM
the pannels in a seven are stressed and have a considerable effect on the stiffness of the chassis.
smart51 - 10/1/06 at 12:31 PM
If you use a steel panel of 1/3 the thickness of the ali you replace then you will have the same weight. You will have to make the steel a bit thinner to counter the weight of the paint or powder coat that you will have to use to stop the steel rusting. If you think that this painted thin steel is better then go for it. Ali is not the answer to the world's problems but it does have its uses.
My ali floor is bonded on to the chassis with PU adhesive and is also riveted at frequent intervals. The adhesive and rivets together will make the ali add to the strength of the steel tubes.
There isn't a problem with ali or with steel. Use what you think best.
Volvorsport - 10/1/06 at 12:41 PM
some pics to clarify my chassis - its a 442 ish size so it will be heavier
http://www.dbsmotorsport.co.uk/Html/index3.html
[Edited on 10/1/06 by Volvorsport]
NS Dev - 10/1/06 at 01:15 PM
The problem will be that using 0.5mm steel (as opposed to 1.2mm ally) will mean that the steel will wrinkle when welded, almost impossible to stop this happening with very thin section sheet steel.
kb58 - 10/1/06 at 03:08 PM
About the riveted aluminum-paneled car not lasting as long, that may be be. But the *real* question is, will the aluminum-paneled car last longer then you wish to own it... If so the whole issue goes away.
Prez - 10/1/06 at 03:23 PM
I cant see anyway of getting a weld of high enough quality to bring any benefits over rivetting and / or bonding, when joining very thin gauge steel plate to box section or tubes with considerably greater wall thickness. IMHO I think you would actually make the structure considearbly weaker for the same given weight.
britishtrident - 10/1/06 at 03:29 PM
Just not issue ----
Early Lotus car were constructed almost exactly the same way as the Locost and there are still a high % number of survivors around that are going on for 50+ years old. I might add Lotus used tube 1.2mm thick.
Re-skinning a Seven style car is no big deal, the alloy gets minor damage with everyday wear and tear.
britishtrident - 10/1/06 at 03:36 PM
Yes ;-) it buckles or to put it anotherway because of the greater thickness an aluminium panel is stiffer in bending than a comparable steel panel -- which is why aluminium and magnesium alloys are such excellent materials for making road wheels.
quattromike - 10/1/06 at 04:06 PM
Plus you would have to have the welding current turned down so low for welding the thin mild steel sheet with mig that it would not fuse to the thicker box section tubes.
Every tried laser welding?
Mike
02GF74 - 10/1/06 at 04:56 PM
is it not possible to spot weld the thin sheet to the square tubes or the difference in thcknesses too great?
using steel has anther disadvantage - rust! so you need rust treatment and paint = more weight!
the question is how much rigidity you gain by a more solid join of sheet to the frame, if you knew that, then maybe you could use lighter tube so shed some weight there.
britishtrident - 10/1/06 at 05:15 PM
In a real world as per book build apart from the floor panel they don't do anything but keep the wind out, to get any structural gain you need to use a decent thickness of panel and lots of carefully spaced rivets and careful use of bonding.
Volvorsports locost (hi-carb !) chassis is impressive because he understands the material he works, nearly everyone else pop-rivets oa thin sheet of unknown grade aluminium alloy sheet with any old B&Q rivets.
Most alumium alloy sheet sold to Locost builders is the same stuff used to make Luton van bodies -- it has the structural properties of tin foil, van builders use it because it is easy to work. The stuff aircraft and old F1 car monocoques were made was a bit different.
[Edited on 10/1/06 by britishtrident]
britishtrident - 10/1/06 at 05:28 PM
Lotus or at least Arch Motors used 1.2 mm round tube for the spaceframes. 1.6 RHS is easier work with.
Early Lotus space frames were a lot sparser than the Locost --- somewhere on the net is a picture of chunky Chapman holding up an Eleven chassis-- just try that with book chassis.
With the Seven Series 2 Chapman tried to take even more weight out cutting out nearly all of the diagonals -- the result was a lot of broken chassis (mainly fatigued brazed joints), with the late Series 2 and Series 3 the missing members were re-instated. Locost are about twice the weight of a Lotus Seven S2 chassis.
Chasing grams on the chassis isn't worth it, the chassis dosen't way a lot compared to the bits bolted on to it.
Philippe - 10/1/06 at 06:25 PM
R-Could you elaborate? I would join the plates to the tubes in a common mig or tig welded spot by spot fashion, the way car bodies are built in the industry. There is nothing weak about that?
Wheter is is better than riveted+chemical bonding, I don't know. This is what I want to find out.
Philippe.
Philippe - 10/1/06 at 06:31 PM
R-I was refering to sequential spot welding. This is the way the industry stitches car bodied together. Punch holes all around the perimeter of your panels, turn the amp at the lowest on your mig welder, weld one second hole at the time, etc.... No distorsion, no buckling, perfect.
Philippe.
Volvorsport - 10/1/06 at 06:32 PM
impressive eh !! wooo .
it could be a lot better - that entails makig another chassis to make the GRP/kevlar bit even better/easier to do , it was quite fiddly but rewarding when i stood in the tub and jumped up and down !!! .
by my rule of thumb , if i can remove most of the tube work within the tub apart from the perimeter frame, and using a rear gearbox UN1 style , i can get one below 500kgs , which aint bad for the volvo turbo lump up front .
Philippe - 10/1/06 at 09:17 PM
R- The panels are not load bearing but they should. Then you would have the perfect combination: a light chassis assisted by a monocoque structure.
Philippe.
quattromike - 10/1/06 at 10:27 PM
Philippe.
I think most of the structual joints of modern day cars are seam welded, which is a bit like spot welding but instead of a contact electrode on ether side of the surfaces being welded together there are little contact wheels which run along the seam pulling the arc between them IIRC.
Did this kinda stuff at the big boys school but that was a while ago
Mike
lexi - 11/1/06 at 12:10 AM
My floor is 16g steel as is trans tunnel and bulkhead. Won`t make no difference to my car as I hope to lose three stone before it`s SVAd. My wife will be riding shotgun and if she happens to drop that purse of hers on an ally floor..
Alex
C10CoryM - 11/1/06 at 12:34 AM
Pretty well all cars here are just spot welded together. Stronger/lighter than rivets but weaker than bonding.
Ive never seen a spot welded car come apart at the seam and I have twisted the hell out of a few of them .
Had a camaro that tore the quarter panel, tore out the door striker, and twisted the car enough the dome light stayed on but there was no damage to the spot welds. Little too much power/traction for the stock body.
Spot welded steel will be just fine. having said that, I intend to use SS structural rivets and also bond the aluminum to the chassis. I want to leave the sides bare aluminum. Havent decided what to do on the tunnel though. The thought of using aluminum there and having a u-joint fail scares me. Not a V8 car though so less likely than I am used to I guess.
Cheers.
locost_bryan - 11/1/06 at 01:58 AM
Cymtriks recommends welding a steel panel under the nose as part of the torsional rigidity improvements.
I've been considering using the roof off my donor Suzuki van for the floor (as suggested by Uncle Ron) - it has stamped ribs running down it's length, so would be nice and stiff.
The original 7 was a little on the flexible side - I'd like mine to be a little stronger around my vital bits (and don't mind a bit of extra weight closer to the ground)
... and I'll save some weight by going for an axle, gearbox and all-alloy engine that are heaps lighter than Ford's
Philippe - 11/1/06 at 10:03 AM
Cheers.
R-Thanks for your reply.
Indeed spot welds need dynamite to be separated. I am currently rebuilding the body of my Suzuki Samurai and I could not separate the plates around spot welds. I had to plasma cut 1" holes around them. So I am confident that welding light gauge sheet steel on a Locost tube frame will be the strongest bond possible. Your idea of using SS rivets/aluminium plates is good too. I would still introduce a bonding agent (epoxy) though in order to provide the skin to chassis bond more integral strength and prevent water penetration in steel tubes.
I hope these thoughts are usefull.
Take care.
Ps. I like the photo of your sister on the left.
Philippe
[Edited on 11/1/06 by Philippe]
02GF74 - 11/1/06 at 11:12 AM
maybe nowadays but I recall a story about Marina or some other BL car from the 70s. The owner would go to the countryside and park the car. He would hear a strange pinging noise once in a while - turns out it was the spot welding coming apart!
Peteff - 11/1/06 at 11:19 AM
Get one of these they're good for splitting panels. I've used them or just drilled through the welds and peeled them with grips or split them with a chisel but that tears the metal so you need to be careful if you are reusing it. You can reweld in a different place to recycle panels though.
NS Dev - 11/1/06 at 11:56 AM
Philippe.
You mean what I would call plug welding, i.e. puddle welding through punched holes with the MIG.
I use this technique a lot, but it still wrinkles 0.5mm steel sheet, in fact it still wrinkles 0.8mm sheet, even when pretensioned.
NS Dev - 11/1/06 at 12:07 PM
The last line of the above is one of the best observations made on here for a while!
Philippe - 11/1/06 at 01:08 PM
Philippe.
R- Thin steel in my experience will buckle if the welding sequence causes it. I believe that I can limit the buckling effect by welding away (in a sequential fashion) from the center of the work. But you are right there is always a bit of distorsion on thin steel no matter what you do. Nothing that could not be flatened out using a torch or in the worse case body filling.
Philippe.
Alan B - 11/1/06 at 01:15 PM
.......Chasing grams on the chassis isn't worth it, the chassis dosen't way a lot compared to the bits bolted on to it.
I'll add my 100% endorsement too....there are many, much better places to save a few pounds.
David Jenkins - 11/1/06 at 01:23 PM
For me, I must lighten the nut holding the wheel (yes, I know I've said it before... quite recently in fact!)
NS Dev - 11/1/06 at 01:27 PM
Surely that one Nyloc doesn't weigh THAT much does it?????
kb58 - 11/1/06 at 03:39 PM
"Chasing grams on the chassis isn't worth it, the chassis dosen't w[eigh] a lot compared to the bits bolted on to it."
But only if that is followed through - I find it's actually the opposite. I think instead the thought "it's just a few ounces, it won't hurt", happens to just about every part of the car.
It's just like dieting where people cheat, "it's just a little bit." That thinking, carried to its logical end, results in overweight people - and cars. I realize we don't have the buget for carbon this or titanium that, but it's still important to always be asking, can I make this (and every) part lighter.
TheGecko - 11/1/06 at 11:35 PM
It's well worth reading "Driving Ambition" by Doug Nye (and Gordon Murray & Ron Dennis) about the design and manufacture of the McLaren F1. Murray set a 1000kg weight target and was fanatical about chasing every spare gram. In the end the road-ready car weighed (from memory) 1100kg, amazing for a 3-seat 5 litre V12 autobahn weapon! Murray said that only setting the (probably unachievable) 1000kg target had kept the design/development team focused enough to reach the (still impressive) 1100kg end result.
Now, none of us are building 300km/h+ supercars (well, I'm not - anyone else want to claim otherwise?) but, as Kurt points out, it's possible to let a "Near enough is good enough" attitude compromise the end result significantly. So, I say, think about those extra grams, even if you decide in the end that it's not worth saving them. At least then it's an informed decision rather than a "swept aside, too small to bother about" dismissal.
Will my car be heavier than it could be. Absolutely! Will I cry tears of blood over that? No because, wherever possible, I have considered the factors and made a decision. In a lot of cases, that decision was that I would accept a (probable) weight penalty in exchange for ease of construction or availability of materials or peace of mind about strength or any of a hundred other reasons.
To try and drag this polemic back on topic, my car will have bonded (sikaflex or equivalent) and riveted aluminium skins. I'm not too concerned about corrosion since I intend not to park the car underwater any more than neccesary. Living on the dryest continent on Earth helps but, that said, we've had 75mm/3" of rain this year and it's only the 12th of January.
Anyway, enough rambling from me. I'm back to the garage to make some more informed, considered decisions about engine bay tube sizes. I think I see a way to save about 4kg!
Dominic
Peteff - 12/1/06 at 12:36 AM
That would be a button weld
NS Dev - 12/1/06 at 12:41 AM
I'm tired so a short reply!
Yep, in order to achieve the ultimate we need to do everything to the ultimate................................................................................................................................but then we must not over complicate things!
Keep It Simple Stupid, as they say!
Look at the Ultima GTR (to current demo car spec)......vastly quicker in a straight line than the McLaren, quicker around a track, less than 1/10 the cost, nearly 200kg lighter, 100 times simpler and uses an ancient engine design that still makes more power!!!! There is no stressed carbon fibre on the car, a steel spaceframe chassis, pop-rivetted alloy panels etc etc.................................................................... Simple is Quick, Colin Chapman taught all of us that but nearly all have forgotten it completely.
Simplicity is the reason that to save weight in my 7, I am simply not bothering with things that I don't need! Maybe I can save a few grammes on the chassis, but having no instruments saves a lot and why do I need them???? What does trim do exactly???? Don't need that. No windscreen, no heater, no wipers, no washers............nothing that I don't need in order to use the car for what it was meant for...FUN!!
David Jenkins - 12/1/06 at 08:39 AM
My sentiments exactly!
Mark Allanson - 12/1/06 at 02:27 PM
Or even a plug weld!
NS Dev - 12/1/06 at 03:41 PM
I know, I'd call it a plug weld to anybody in the UK!
I used the "nondescript" terminology on seeing that the person I was answering was not from our shores and may not understand our terminology.
Peteff - 12/1/06 at 06:36 PM
It had already been called a spot, plug and puddle weld, I just thought I'd throw another one in there
NS Dev - 12/1/06 at 11:37 PM
lol
locost_bryan - 13/1/06 at 04:10 AM
Wasn't that Mazda's approach with the new MX5 - shave a little bit of weight off every component (even the door handles!)
cossey - 13/1/06 at 04:33 PM
has anyone tried epoxying the floor on rather than using pu glue which isnt rigid so wont kelp with the stiffness of the chassis?
NS Dev - 13/1/06 at 05:22 PM
no but epoxying it on is a much better idea!
Would have done but for the expense of the epoxy!!
smart51 - 13/1/06 at 05:56 PM
Epoxy can be a bit brittle and doesn't stick to its full potential unless the surfaces are impossibly clean.
PU is very sticky and is flexible. it is less likely to brake or come loose even though it is perhaps less strong.
